Any issues with mis-matched hose sizes?
   / Any issues with mis-matched hose sizes? #11
At the low flow rates used in ag, laminar to turbulent flow or back is not an issue. Downsizing in a line is not really different than inserting a flow restrictor....metal disc with a calibrated hole in it.....Your tractor hydraulic system has different sizes in the casting and connecting tubing, right angle fittings and this and that....then there are the control valves and all.
Don't worry about it but expect slower responses as you downsize parts of the system as others have indicated. Sometimes it's good, like when you are using a hydraulic operated implement of considerable weight that you don't banging down when you drop it.....this is usually where the flow restrictor is used.
Most tractors already have a variable restrictor whereby you can set your raise/fall rates. Not an expert, just things I picked up over the years.
John Deere 6120M (A57148)
John Deere 6120M...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
excavator trenching bucket- one bucket per lot (A56436)
excavator...
Yamaha Golf Cart (A57149)
Yamaha Golf Cart...
