Any of you re-build a torch regulator?
   / Any of you re-build a torch regulator? #11
Thanks, I was not planning on oiling it, but didn't even think about the O2 vs oil thing. So would a de-greaser type like Simple Green be ok? I use that for just about everything.
No Simple Green. I would say pick up a spray can of "Gun Scrubber" at Walmart or a Fleet store that has guns. You Need a solvent that evaporates and is gone. Try not to get any on the rubber or plastic parts.
   / Any of you re-build a torch regulator? #12
I use electrical contact cleaner. It leaves no residue and is compatible with most o ring material and plastics.:thumbsup:
   / Any of you re-build a torch regulator? #13
Dynaflux 365-16 Safety Solvent is used by regulator rebuilders.
It uses dichloromethane and alcohol.
Gun Scrubber uses hexane and alcohol, which is IMO probably fine but I can't find any references for it being in oxygen-safe protocols. It's used in electronic cleaning.
I'll try some on my guns though.
Use all solvents in well-ventilated areas and Google the MSDS (Material Safety Data Sheet) for anything you may contact or inhale.
   / Any of you re-build a torch regulator? #14
Safety Solvent is the coolest degreaser. I have 2 5gln cans. Non Flamable too.
   / Any of you re-build a torch regulator? #15
Dichloromethane = methylene chloride. Same thing, different name. Not something you want to breathe or get on your skin... Yeah I know people used to "bathe in it" but we have learned better over the years. As long as you wear good gloves, a proper respirator and -especially - have good ventilation it should be fine.
   / Any of you re-build a torch regulator? #16
I could be wrong but the 2 cans I have say something like Trichlorathane? and below that it says Safety Solvent and Non Flamable. Made by a company named Crown. 1 Whiff will back you right up but it cleans like nothing I have ever tried.The Feds put a ban on it in the early 90's stating that it killed the ozone. Cleans like nothing else..
   / Any of you re-build a torch regulator? #17
Trichloroethane. Otherwise known as "Tri-chlor" That is exactly what it is used for - degreaser. What they mean by safety solvent is that it is non flammable vs most cleaning solvents which were very flammable, but it is still pretty nasty stuff - it just won't burn.
   / Any of you re-build a torch regulator? #18
Rebuild kits available for firepower regulators on eBay and Amazon just punch in part numbers in google and the should pop up
I just rebuilt two sets no problems
Firepower is part of victor welding supplies
Cheers
2011 KENWORTH T800 KILL TRUCK & TRAILER (A53843)
2011 KENWORTH T800...
2014 CATERPILLAR 826G LANDFILL COMPACTOR (A51406)
2014 CATERPILLAR...
2011 PROCO 130BBL VACUUM TRAILER (A53843)
2011 PROCO 130BBL...
(INOP) JOHN DEERE TS GATOR (A51247)
(INOP) JOHN DEERE...
2013 Ford Transit Connect Van (A52377)
2013 Ford Transit...
2020 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2020 PRINOTH...
