Any secrets for removing Scag blades?
   / Any secrets for removing Scag blades? #1
aloha
Hawaii - Big Island
Kubota B7800 / Kubota RTV X900 / Scag Turf Tiger
I have a Scag Turf Tiger and have been unable to remove the mower blades.
The owner's manual says nuts are torqued to 75 ft. lb. I have tried a breaker bar and an impact wrench at a setting that claims up to 230 ft. lb., and have been unable to budge nuts at top or bolts at bottom of any of the spindle shafts.
I have generously sprayed WD-40. There is no sign of rust or damage to threads to explain why they seem frozen. Any suggestions are appreciated.
   / Any secrets for removing Scag blades? #2
If the Scags bolts are anything like the eXmarks, a breakover bar wont touch them.
I do not know what my Ingersol Rand Impact rating is but, it works like a charm on the eXmark. I bought it when I bought the eXmark because I tried the breakover bar.......:mur:
And did you try reversing the impact, maybe they are reverse threads
I thought about the possibility of the threads being left-hand, but enough thread protrudes to see that they are normal right hand threads.
   / Any secrets for removing Scag blades? #4
I have a wildcat, the threads are definitely not left handed. Mine are usually very easy to take off with my electric impact wrench. If I overtighten I have one that sometimes I have to use a breakover but its not too difficult then. I'd do some liquid wrench and then replace all 3 bolts - they have been way overtightened I think.
When I put them back on I barely let the impact tighten them at all so they won't be hard to get off.
   / Any secrets for removing Scag blades? #5
The last time that that I changed my blades, two came off easy and one was a bear. My impact is rated for over 500 pounds and it wasn't moving. I sprayed the nut with some 3 in 1 penetrating oil and waited an hour. Then it came off easy.
Eddie
   / Any secrets for removing Scag blades? #6
I have had the same problem with my Scag Wildcat. In fact I have busted 2 bolts trying to get them off. I have since been using a torque wrench when putting them on. I have not busted any since, though the last time one came off pretty hard but finally let go. I do feel I had been over tightening. I could be wrong about this but I wonder if when you scalp the dirt hard if that could be tightening the nuts on tighter. I seldom do this anymore which could also explain why they come off easier. We have a clay soil here and I have seen these blades dig into the dirt and bend them and they are tough blades. Some I have been able to bend back with a press but some are just ruined. After going through a few blades and 2 bolts I have learned to be very careful about scalping. I will try using some penetrating oil the next time one comes off hard and hopefully that will help.
Dan
   / Any secrets for removing Scag blades? #7
I suppose it could also be a function of how often the blades are removed. I take them off and sharpen them about every 15 hours, 20 at the most, and I make sure I don't overtighten. Or maybe removing them often just keeps them limber.
   / Any secrets for removing Scag blades? #8
From time to time on my Tiger Cub they get a bit too tight...I now use torque wrench and have no problem but I sharpen about once every two weeks...about 15 hours.
   / Any secrets for removing Scag blades? #9
I spoke to the eXmark dealer regarding this, as I had a cup washer break when I put new blades on last week
He said everyone he knows just impacks the bolts on and off
I asked him after 10 years should I consider replacing the bolts, he said he wouldnt
   / Any secrets for removing Scag blades? #10
I use a stout electric impact wrench on my TT's blade bolts and it works fine, but since new I also made sure I used a little dab of anti-seize paste on them occasionally when tightening them. If yours are that much trouble to get off I'd definitely buy three new bolts and nuts, and use a big time breaker bar (with a pipe cheater handle) on the old ones. They'll either come off or twist off. If you have a small torch (propane would work) it wouldn't hurt to also heat the nuts a tad first. If you break one getting it off, so what. Then I'd trashcan all three of the old bolts and nuts and use a touch of anti-seize compound on the new ones. A two-dollar tube of anti-seize from the auto parts store is worth gallons of penetrating oil!
2016 Doyle 10T Tender (A56435)
2016 Doyle 10T...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
