dntfxr
Platinum Member
I put a new clean gas lense on and I'm getting great results finally! I knew something had to be wrong, I watched "welding tips and tricks" video about AC balance and he had a bad lense that was causing welds to look almost as bad as mine lol. He replaced it and he was back in business. I did the same and BINGO! A clear puddle and clean welds finally!! I also figured out this welder is underrated on amps, I can weld 1/8" alum on low range which is from 10-45 amps AC. Middle range works a little better but will melt 1/8 very quickly. I can't imagine what I'd need the full 310 amps AC or DC on high range though, maybe a battleship lol! Anyway thanks to all for the suggestions and help so far, much appreciated. I want to set up a water cooled torch next few weeks too. This WP26 gets too hot to hold pretty quickly, I don't think it'll survive long using it without letting it cool. Any suggestions on which water cooled torch would be a good match for my rig? I may try to use a transmission cooler mounted behind the fan for the coolant once I get the new torch. Thanks for any suggestions
