Any threads on splitting a tractor? Clutch problems
   / Any threads on splitting a tractor? Clutch problems #11
R W said:
Look under Ford 7710 Clutch Replacement.
It is on this Forum.
Ha Ha, I tried the ford 7710 clutch search and nothing come up but I know the thread starter and the thread is HERE and some of these forum searches don't do so well
I hope it helped. I use Yahoo search and I used to have a SEARCH THIS SITE feature and it doesn't appear anymore?, I liked it
   / Any threads on splitting a tractor? Clutch problems #12
You didn't mention having an implement hooked up at the time, but if you have anything attached to the pto, make certain it's out of gear and/or unhooked. (i.e. a mower....)
Jack one rear wheel slightly off the ground and try to rotate/rock the wheel just a tad. Hopefully that'll "un-bind" things and let you find nuetral.
And of course, those Fergies were proned to hanging in gear. Some will even go into 2 gears at the same time. There's been millions of threads on the 'net on how to "un-stick" a Fergie tranny that's hung in gear. .
TO-30 is about as easy as it gets to split. I prefer to support the front half well, and roll the rear half back when splitting that tractor. Single stage clutch should be simple enough.
Get a SERVICE manual. (not the same as an owners manual) Much more detailed, usually having info on what to unhook for a split.
R W said:
Look under Ford 7710 Clutch Replacment.
Thank You!
Hi,
*I have the srevice manual.
*I unhooked the box blade and dragged it away
*I chained the tractor to my 4x4 Trooper and drug it backwards about 2 feet, then it was very easy to get into neutral.
Now I need to pour a slab in my implement shed so I can split it... Hopefully soon the ground will be dry enough for a cement truck.
Thank you for the advice!
Thanks for the link!
UNUSED Yellow Outdoor Patio Fabric Screen (A53117)
UNUSED Yellow...
SDLANCH MINI WALK BEHIND SDLL30 LOADER (A53843)
SDLANCH MINI WALK...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
THE HANDLER II MIXER UNIT (A53843)
THE HANDLER II...
