Anybody here use solar well pump?
   / Anybody here use solar well pump? #12
My well is 100% solar. I did it all myself.
It has been flawless for over 12 years. The down hole pump is a Grundfos 6fx I think. It is a multi voltage pump that will run on almost any voltage Ac or dc. I run mine on 6 solar panels producing 72 volts at about 400 watts. It pumps about 3 gallons a minute on the 72 volts. i pump into a 1500 gallon storage tank.
from the storage tank I use a separate pump to pressurize my pressure tank. I use 6 12 volt 40 watt panels in parallel to charge a storage battery that drives a 12 volt RV type pump. That pump charges the pressure tank.
I don't need it but I can pump an easy 1000 gallons a day if I had to. It is simple and it works. Trying to use the same pump to pump from the well and charge a pressure tank with solar is not a good idea. Most pumps simply will not do it. My well pump is multi voltage and I can run it off of a generator if needed. I have only had to do that one time.
If grid power is not available, a system like Jimbrowns works very well. However, if you have grid power available, a house pump only uses about a nickles worth of power every day. It would be impossible to justify the cost of a solar pump system with electric savings. It will cost more just to maintain and replace those batteries than it cost to pay the electric bill for a grid powered pump.
   / Anybody here use solar well pump? #13
Yah this makes a lot more sense! A pump barely big enough to deliver something like 20 psi and a few gpm to SLOWLY fill a reservoir......then a second pump to deliver normal pressure and flow to the house.
If you just want to boost pressure from a cistern, you don't need much pump. A centrifugal pump is lousy at sucking, but if you can provide even low head water to the intake, it will pump like a bandit. I have a cistern and use a 1/2 hp centrifugal, and it pumps all the water I need for domestic use or 1-2 sprinkler irrigation. I'm not going to walk out and check, but seem to remember that it draws 6.3 amps at 240 volts if it's running wide open, and of course a lot less than that if it's just filling the pressure tank. I have it wired with a couple hundred feet of 12/3, and it has been running for years with no problems.
I only wanted solar because of power outages, not to save money on electricity. Not as a backup like a generator, but just replace electric with solar power. Alas, won't work for me. So I forget it. Gracious mi amigos.
   / Anybody here use solar well pump? #15
A cistern is a great way to have water during power outages. My cistern is a 2500 gallon spun poly tank, which I installed just because the well flow is very low during the summer. I placed it so the bottom of the cistern is about 6' above the floor of the house, and the cistern is 8' tall, so with no power at all I have 12' to 14' of head. That's enough water to refill the toilet when you flush, or get a glass of water at the sink. If we want a shower we have to fire off the generator to heat water and run the booster pump, but an hour or two of electricity a day is plenty, even under horrible conditions.
   / Anybody here use solar well pump? #16
I've been wanting to do a solar powered pump on my land to fill a tank that I can use to water my wife's vegetable garden every day. Her water usage adds over a hundred dollars a month to my water bill, which is all city water. My thought was that as the sun came up, it would start charging the solar cells and they would power the pump. Water is only ten feed down where I want to get it, and then about a thousand feet to the house, and up another 30 feet including the height of the tank, so 40 feet max lift from the water to the tank. It's a big project and the cost up front is more then I want to spend. I honestly never thought about running power down there and pumping it that way. Now I'm wondering if I have over thought this, made it more complicated then it needed to be, and if it would be cheaper to just run power down there and be done with it?
   / Anybody here use solar well pump? #17
My neighbor with the two solar pumps - post #5 - never thought about saving money with solar. He DID think wind/windmill but the wind isn't constant enough and anything of this type he could find required more maintenance than solar and the initial cost was considerably more. I know if commercial power ever became available - he would get off solar in a heartbeat.
   / Anybody here use solar well pump? #18
A shallow well pump would pull water through 1,000 feet of pipe as long as the vertical distance is 25' or less, it's the vertical distance more than the horizontal that is the limiter. Put the pump where the pipe is closest to the house and save all that wiring. The big thing to worry about is freezing. It may end up the easiest way to protect the pump from freezing is to put the pump inside the house, run the pipe from the well to the house and then from the house to the garden. Even if it means more pipe it could be less work.
   / Anybody here use solar well pump? #19
Another obvious point that I didn't think of. No need for all that wiring, and I can easily build a pump house next to a storage tank by the house. Priming it might be an issue, but I always have the city water and a hose to do that, so it shouldn't be too hard. Thanks!!!!
   / Anybody here use solar well pump? #20
Your city water system will be paranoid about cross-connections contaminating their system. At the very least, you will need a double check between your home system and the city system, and it will have to be inspected annually. That's if they will let you have a well system at all. They may just pull the meter and deny you water service. I didn't realize you had city water. That's a can of worms.
2025 JMR Tree Boom Skid Steer Attachment (A55787)
2025 JMR Tree Boom...
2004 Ford F-250 Liftmoore 2,700 LB 1 Ton Crane Service Truck (A55788)
2004 Ford F-250...
6 Yard Commercial Dumpster (A51692)
6 Yard Commercial...
2014 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2014 Ford F-150...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
