Anybody try the newer R14 tires?
   / Anybody try the newer R14 tires? #11
You need to take into consideration that the R14T's are radial tires and the R4's are most likely bias.
The ballooning is evident, 12, 06, 03, and 09 O'clock, loaded or unloaded.
SDT
   / Anybody try the newer R14 tires? #12
   / Anybody try the newer R14 tires? #13
I have r14t tires on my new m7060 with 140 hrs and I love them. The tractor came standard with a 6 ft bucket and the dealer upgraded to a 7 ft at my request. The tires do balloon some with the bucket full but not to the point that I would reconsider getting something else. My opinion of which tire to buy is this: Traction R1-Loader R4-Turf R3 but if you are looking for the tire that comes at number 2 in each of these categories then R14 is it plus they ride very smooth on the road. I bought a hd one shank subsoiler rated for minimum of 40 hp and and I need all 70 horses to pull it in my hard clay soil but no problem as far tire traction. I am considering purchasing a 3 cu yd dirt pan, if the tractor can handle it, I know the tires can
Any pictures of tractor so we can see how those tires look? I saw some on a JD 5000 series and they sure looked impressive.
   / Anybody try the newer R14 tires? #14
On clean turf, with a short test, it shouldn't be surprising that a turf tire has the best traction. But it's not all about traction, and especially not only on firm short turf. You should consider your own intended use. How do these tires perform when in long pulls through soft soil, mud, snow, up inclines. How will the tread load with dirt/snow and lose traction after a few minutes. What about ride comfort if that's important to you, and road use etc. Lots to consider and no single correct answer.
   / Anybody try the newer R14 tires? #15
I was more worried of bulging side walls and higher probability of flats. If doing heavy loader work or operation in wooded or rocky conditions R14s don't look like a option. More of a lawn and garden tire. A turf tire with a little better performance in snow.
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
1995 Koehring LRT-110 7.5 Ton 4WD Rough Terrain Crane Truck (A55787)
1995 Koehring...
2015 Vermeer SC362 Stump Grinder with 2018 S/A Flatbed Trailer (A56857)
2015 Vermeer SC362...
2003 Ford Pressure Digger Truck (A55973)
2003 Ford Pressure...
2025 MS380R Mini Stand-On Track Loader Skid Steer (A56857)
2025 MS380R Mini...
