Richard -
I'll jump in here since I'm sitting @ my computer now anyway.../w3tcompact/icons/wink.gif
<font color=blue>I 'think' a r**** is either center or rimfire also...</font color=blue>
For practical purposes, yes, these are the only two types. (Unless you want to talk about flintlocks, percussion, or some other "weird" things out there.)
<font color=blue>Isn’t the center/rim firing method only related to how the primer cap gets hit and thereby fires the round?</font color=blue>
Correct.
<font color=blue>My logic says...things identical with the only difference being center -vs- rim fire...that BOTH ought to have the same gas pressure, velocities, impact and all those other things.</font color=blue>
Well, logically it would seem to work out that way, but the problem is that there are a lot more variables in the equation and therefore it doesn’t really work out that way you deduced.
As Ed pointed out, practically speaking, the only rimfire ammo being made now is in .17 & .22 caliber @ certain velocities. (I'm ignoring all the rimfire cartridges developed in the 1800's here because even though you can scrounge up some ammo, I don't know of any arms made in the last 100 years that use these oddball cartridges.)
Currently there are no centerfire cartridges (even at reduced loads) that mimic the velocities/energies with the same bullet as the current rimfire offerings. (The centerfire rounds are far faster even with the same bullet.) So a true "side by side" comparison of "equivalent" rimfire and centerfire cartridges can't be done practically.
That being said, lets look at the "what if" aspect. Going back to my previous post, I mentioned how you can change recoil energy & velocity even when the projectile (bullet's) E/V stay the same just by changing powders. Keeping the bullet's E/V the same, but changing the powder type will also change the internal pressures because different powders burn differently. But it goes even further than that...
Within a centerfire r**** cartridge, you can change the bullet's E/V (and internal pressure) just by changing the brass or primer you use! /w3tcompact/icons/shocked.gif The brass can change pressures & velocities due to wall thickness/construction (e.g. thicker walls, less internal volume, ergo higher pressures). The benchrest folks get down to where they will weigh each empty brass cartridge (even within the same manufacturer) so things remain consistent for their shooting, and hopefully result in tighter groups.
The primers also make a difference. You can get different primer flavors for a given cartridge type. You can get “standard” primers, or “benchrest” primers, or “magnum” primers, for example. All of these primers fit in the same hole and function in the same way (unlike comparing rimfire to centerfire) and they can (and do) have an impact (sometimes dramatic) on pressures, accuracy & velocity even when all the other variables are kept the same. It isn’t odd for those who reload to find that a particular cartridge combination shoots much better when they switch the brand of primer they are using when everything else is equal. (bullet, brass, powder, charge, primer type - i.e. ‘standard’, etc.)
So, getting back to your original question, since rimfire primers work in a totally different way (they way they ignite and burn pattern they initiate), even if you could use the same chemical content in a rimfire primer that you used in a centerfire primer, it would most likely result in a completely different outcome with regards to accuracy/pressure/velocities with everything else being equal.
Hope this helps! /w3tcompact/icons/smile.gif
PS: <font color=blue>I might end up at the local sporting outlet looking at these things.</font color=blue>
I hope you do! We need more good folks to become interested in the shooting sports! /w3tcompact/icons/wink.gif
Fun fact:
For those who reload, you are always supposed to "work up" to a particular powder/brass/primer/bullet combination with reduced powder charges whenever one of the component variables change due to pressure considerations. (Guns can literally "blow up" if you screw up and exceed safe pressures. /w3tcompact/icons/sad.gif)
Just for reference, internal pressures in modern rifles can go as high as 50,000+ cup/60,000+ psi and powder measurements are generally in tenths of a grain (gr) or 1/70,000 of a lb.- BTW, cup is a measurement method and therefore there is no direct mathematical conversion from cup to psi. That’s why the reloader types tend to be kindof precise and also pretty respectful of their hobby. /w3tcompact/icons/wink.gif
