anyone here own an econotig?
   / anyone here own an econotig? #11
I bought one and was away for sometime before I got it out of the box. The tig side has never worked properly, no power. I sure does a nice stick job though. Still I bought it for the tig but too late to turn it in on warranty.
   / anyone here own an econotig? #12
-rb- not to hijack the thread but could you describe the setup you used for tig? Maybe I can help.
   / anyone here own an econotig? #13
I just set it up like the book says as far as the switches go. barely has enough arc to make a mark muchless make anything of a puddle.
   / anyone here own an econotig? #14
RDBRUMFIELD,
SIR,
are you sure you have the machine in the correct
mode, for TIG? there is a switch that has to be moved
for each operation, and it sounds like the machine is in
the stick mode, when you are trying to TIG weld.
good luck with your projects.
accordionman
wlbrown
wright city, mo.
   / anyone here own an econotig? #15
Also where did you set the amps at (0 - 100%) large center knob? Also did you get the thumb control or the foot control? If I can get a chance I'll get a picture of my setup.
Good luck.
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A59823)
1987 CATERPILLAR...
2020 Ford F-250 Ext. Cab Service Truck (A59230)
2020 Ford F-250...
2023 FORD F-650 SUPER DUTY CAB AND CHASSIS TRUCK (A59823)
2023 FORD F-650...
Jaw Crusher (A59228)
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
2018 CASE 340RT TRACKED TRACTOR (A60430)
2018 CASE 340RT...
