Anyone know where the seat and PTO switches go?
   / Anyone know where the seat and PTO switches go? #11
Wayne -
Sorry I didn't get back to you - crazy weeks up to and including this one - on the road at big trade show in Chicago...
Ok - so your B7610 cuts out when you start to get up from the seat - IIRC then there are three possibilities:
1) PTO switch
2) Seat Switch (which seems fine since something happens when you get up - makes me think it is doing it's job correctly..)
3) The HST "neutral" position
Since you've looked into the PTO switch - I'd next try the Forward / Reverse HST pedal switch. I know there is one - 'cause (don't try this at home folks) sometimes when I'm trying to align a 3PH connection (ex snowblower) - and I'm off the tractor - I try to "inch" the CUT forward / back a bit to correct the 3PH / implement alignment. If you go "gentle" on the HST pedals - you can move the CUT a little bit - but if you really try an push a HST pedal - the engine quits.
Hope that helps - and sorry for the delayed answer. Any news from your end?
Dan
PS With the new forums - the link to the other thread was lost - here it is again: http://www.tractorbynet.com/forums/showthread.php?t=79161
The thread starter replied back that he found "dirt" in his BX24 HST pedal - and that his problem ceased when he cleaned it...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A51691)
Generac Yanmar...
2015 HAMM H11iX SMOOTH DRUM ROLLER (A52706)
2015 HAMM H11iX...
2018 Kubota RTV-X900 4x4 Diesel Utility Cart (A55851)
2018 Kubota...
2015 Ford F750 Reel Loader Truck (A52377)
2015 Ford F750...
2012 Ford Transit Connect Van, VIN # NM0LS7DN0CT092703 (A54865)
2012 Ford Transit...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
