Anyone load their front tires?
   / Anyone load their front tires? #21
I need to load mine with Helium so i can lighten my tractor and be able to haul it on my trailer. After doing the calcs, i now have to sell my old 16' flatbed trailer and get a new one that can carry more weight. ahhhh.
   / Anyone load their front tires? #23
I know (almost) everyone loads the rears. Anyone load the fronts on the mfwd's? Looks a easy way to pick up a couple hundred lbs (far cheaper than 2 more suitcase weights), but the tire guy I asked thought I was nuts.
Make any difference with a load hanging on the 3pt?
i have to customers with 1715 fords 4wd that i have loaded to fronts on mainly for the extra weight up front when picking up the bush hog
That's sort of what I had in mind. I have a 2500 lb drill that hangs a good bit back. I could probably do better to just grab a half bucket full of dirt when I need it, was just curious if anyone did it.
   / Anyone load their front tires? #25
when I had my NH TC35 my dealer loaded all four tires and I never had any issues in 600 hours, when I bought my Kubota L4200 my dealer said no to loading the fronts, he said corporate said not to do it. just mt .02 worth.
   / Anyone load their front tires? #26
Just my two cents and if I owned, I'd not load the fronts for most any reason. More wear everyday!!!
   / Anyone load their front tires? #27
It helped on an 800 Ford handling 3-14" breaking plows many years ago. I would be interested in technical reasons a tractor company would be against it.
   / Anyone load their front tires? #28
I had my front tires loaded when I purchased my DK40 last year . Mainly because of the 72" heavy duty woods rotary cutter I use . I dont mow with the FEL attached . My last tractor was a ford 3600 and my Kioti does handle the cutter better .
   / Anyone load their front tires? #29
What pressure do your run in the fronts then? Much lower? I was driving down my not so smooth driveway with a fairly full bucket of gravel and I was glad the fronts had lots of give to them. It must be easier on everything from the front axle to the loader.
I know my dealer put my back tires to 15 psi or so to make up for the lack of compressability of the rim guard.
MASSAGE CHAIR (A58214)
PumpJack Brand Pump Jack (A56438)
PumpJack Brand...
2020 ASV RT65 (A60462)
Case 1020 25ft Draper Head (A56438)
Case 1020 25ft...
2007 Ingersoll Rand G240 240kVA 3-Phase Towable Diesel Generator (A59228)
2007 Ingersoll...
Hydraulic Liftgate (A59230)
Hydraulic Liftgate...
