Anyone mount a "T-Post Puller" on FEL or 3-pt?
   / Anyone mount a "T-Post Puller" on FEL or 3-pt? #11
Re: Anyone mount a \"T-Post Puller\" on FEL or 3-pt?
</font><font color="blue" class="small">( BTW - In response to the last post, I only have 2 hooks on the FEL and I cannot imagine a scenario where the T Posts would bend any part of my bucket... )</font>
Mike,
Didn't mean to mix a couple subjects here. It was a sidebar about hooks. Not T-posts, but something heavy was lifted which is what bent the top of my bucket.
Brian
   / Anyone mount a "T-Post Puller" on FEL or 3-pt? #12
Bob,
I use an el-cheapo hand operated (GASP!) T post puller. I have found it to be quicker than positioning the tractor and 2-3 trips on and off it to hook the chain, etc. just remove the wire and post all in at the same time, is easy, cost about 15.00 at Harbor freight. I know this does nothing to justify tractor ownership though. Well maybe, I do use the bucket to hold/carry the pulled posts.
Ben
Ben, you and I do it the same way, but with my heavy clay I usually end up struggling even when using the jack to pop them out. I was looking for a way that would use the advantages of the hydraulics rather than the muscle strength of the hand jack.
   / Anyone mount a "T-Post Puller" on FEL or 3-pt? #14
I have some old tow straps that I use with the tractor for pulling old trees, etc.
I used it to pull up a few old signposts in my field - worked great. I just wrapped it around the FEL nice and secure, and then wrapped one end around the bottom of the post - you don't have to tie it, as just wrapping it a few times makes it very secure. It popped them right out, didn't bend them, and was easy to unwrap the strap. Alot lighter than chains.
   / Anyone mount a "T-Post Puller" on FEL or 3-pt? #15
Here's what wroughtn harv uses for pulling posts...
harv's post puller
Don
   / Anyone mount a "T-Post Puller" on FEL or 3-pt? #16
Just another use for a 4n1 bucket /forums/images/graemlins/laugh.gif… a light pinch and they lift right out. KennyV.
   / Anyone mount a "T-Post Puller" on FEL or 3-pt? #17
Bob,
I have heavy red clay with flint rock. I don't have any problem pulling t-posts, but my tractor is larger than yours. I have two hooks, one on each side in-line with the hydraulic cylinders. I wrap a chain around both hooks and then hook one end to the chain in the middle. That way I have all of the pull in the middle.
   / Anyone mount a "T-Post Puller" on FEL or 3-pt? #18
Basically what I did was to take the puller attachement (the part that slides over your T-post and put that on the end of a chain using a screw link. Wrap that chain around your FEL. Drop it over the fence post (it works easier with two people) and lift. It is a breeze!
Doug /forums/images/graemlins/cool.gif
   / Anyone mount a "T-Post Puller" on FEL or 3-pt? #19
Here is the picture of Harv's puller
   / Anyone mount a "T-Post Puller" on FEL or 3-pt? #20
Bob, You're getting good info. My setup is similar to some already mentioned. Blow two holes maybe six inches apart in a short heavy metal plate. Hook a short pc. of chain in one hole and attach the other end of chain to bucket(I hook to my hayspear) raise the bucket high enough and you can manuever the plate's other hole over the post from the tractor seat and pull. Doesn't bend one often or bad. A more professional pulling bracket is readily available (sans chain) at local CO-OPs for about 10-15 bucks.
TK
2001 HAULMARK ELITE II 8' X 24' CARGO TRAILER (A51247)
2001 HAULMARK...
2013 MACK PINNACLE (A53843)
2013 MACK PINNACLE...
2006 Kobelco SK210LC Hydraulic Excavator (A52377)
2006 Kobelco...
TEXAS PRIDE TRAILER (A53843)
TEXAS PRIDE...
2000 Ford F-350 Stakebody Flatbed Truck (A51692)
2000 Ford F-350...
2001 JUSTIN 14 MOTORCYCLE TRAILER (A53843)
2001 JUSTIN 14...
