Anyone taken apart a CC 1440 belt clutch?
   / Anyone taken apart a CC 1440 belt clutch? #1
jimmysisson
W.Mass
1993 NH 2120 (the best), 1974 MF 135 (sold, but solid), 1947 Farmall A (bought, sold, bought back, sold again), 1956 MH50 lbt (sold, in 1980, darn it)
I find a 14mm nut on the front of the clutch, marked LE with three lines around the flats, like a grade three bolt. I don't want to put a wind wrench on it without knowing if it's left- or right-hand threads. I think I ought to remove it, 'cause there's sparks coming out from the engine side of the clutch and some funny smells. Darn, I just got the dumb starter replaced and 1½ hours later this clutch goes. Oh well, it's otherwise problem free.
So, anyone have a service manual or experience with this clutch? This is an early 90s Briggs 14hp Vanguard, with the electric blade clutch gone south.
Thanks in advance.
Jim
   / Anyone taken apart a CC 1440 belt clutch? #2
Does clutch still engage when voltage applied to it? Probably a bearing went bad allowing outer assembly to run at an angle and short coil on inside. I am thinking this works like an automobile a/c clutch right? If you can replace bearings and get it to run true again, should stop throwing sparks due to metal to metal contact or electrical short.
I agree with your diagnosis. I'm hoping for help in getting the thing apart without breaking something. Thanks, jim
Just FYI, the bolt is regular right thread. I found cooked bearings, scuffed windings on the clutch armature, etc. Too bad, but gotta be fixed.
Jim
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
New Holland B95 Backhoe (A50490)
New Holland B95...
Engel 20' Boat (A50121)
Engel 20' Boat...
1996 FORD F SERIES DUMP TRUCK (A51406)
1996 FORD F SERIES...
2018 Atlas Copco Pas200HF Diesel Dewatering Pump (A52377)
2018 Atlas Copco...
