Anything like a side flail mower for compact tractor?
   / Anything like a side flail mower for compact tractor? #1
jinjimbob
USA
Kubota B2320
Is there anything available like this , Compact Range of Professional Side arm Flail Mowers, for a B2320, something to trim back blackberry bushes on the side of the driveway and road.
That looks pretty spendy and I'm sure my tractor is too small for anything like that.
thanks
   / Anything like a side flail mower for compact tractor? #2
thanks
The vineyard attachment on one brand has two and three sickles to prune on all three sides for pruning grape vines in one pass and it may be what you want as it would be capable of trimming and pruning for you.
I can forward some information to you about flail and sickle pruners as I have it stored.
One manufacturer has very small tractor rear mounted boom flails that can do this as well as mow.
send me a PM with your e-mail and I can forward it to you.
Edit 5 august 2010 I totally forgot the Samurai it would be perfect if you have a front end loader to aid in trimming
   / Anything like a side flail mower for compact tractor? #3
Most manufacturers have an offset flail mower that mounts on the 3-point but mows past the RH rear wheel a foot or so. When you are talking flail mowers you are talking $thousands. What you buy is a mower that will chew through stumps and 4" logs without burping. For the money, I pull out my chainsaw and do the big stuff myself.
   / Anything like a side flail mower for compact tractor? #5
The John Deere 90 was made for tractors up to 50 HP. Not sure about the low end. I'll have to dig out my manual tonight after work and look it up. My tractor is actually a little big for it.
   / Anything like a side flail mower for compact tractor? #6
I side trim my Osage Orange hedge trees along my drive with this... it works great and I can also trim ditches. KennyV
thanks guys, that Samurai sabre looks great.
I just to figure out how to connect the hydraulic lines.
I do have both a front end loader and back hoe connected.
   / Anything like a side flail mower for compact tractor? #10
2007 Mack MR688S Sermac 5RZ53 53 Meter Concrete Pump Truck (A45336)
2007 Mack MR688S...
Toro 30672 32in Walk-Behind Mower (A44572)
Toro 30672 32in...
New/Unused Hydraulic Pallet Forks (A44391)
New/Unused...
Year: 2001 Make: Ford Model: Excursion Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: B... (A44572)
Year: 2001 Make...
2014 Ford F-150 Crew Cab Pickup Truck (A44572)
2014 Ford F-150...
(2) New/Unused Welding Helmets (A44391)
(2) New/Unused...
