Apps for land survey - Property lines
   / Apps for land survey - Property lines #21
Thanks Dodge Man. Unfortunately I do not have plat. I just bought the property a couple of weeks ago and the guy I bought it from had it since 1987 and he said he never had it surveyed. It was a rush transaction I have been trying to buy it from him for nearly ten years but he would never sell and then all of a sudden he left a note in my mailbox saying he would sell it to me as he was in a bind and needed the money. We closed 6 days after he left that note. I do think it was surveyed at some point but I don't think Texas is a recording state but I will double check.
And you are correct on the 60'. The actual corners are in roads and I am not sure if the spikes are intact as I know the roads have been repaved several times. I think my best bet is the 60' in 1/2" rods. Then again adjacent to this 5 acres on the other side of the road they just broke up 60 acres and sold it off in ten acre lots which I saw survey markers on. They likely found and used the section corner but I don't know.
I will be using a R10 to navigate with. I have six of them and use them almost daily but that is all done in state plane coordinates. The only survey plats I ever really work with are for oil wells and they always have eastings and northings for the points as well as bearings and the basis for them. I am kind of a nerd with this stuff I have 5/8" stud welded up on my property and have collected three weeks of static data and have a really good OPUS solution for my base. I use it all the time to survey various things on my property like anytime I bury a water or electric line, etc.
   / Apps for land survey - Property lines #22
We just bought a new R10 system less than a year ago. Two R10s, internal low power radios, an external 35 watt radio and they are both VRS capable. It was 46k total for them. We already had two data collectors. Trimble is pretty proud of their stuff.
I can tell by reading your description it has been surveyed. If it’s older probably pre dates GPS. If you have state plane you can calculate the difference between grid north and geodetic north. I believe it’s the Greek letter Theta. If you have ever used NGS data sheets you can find one in your area that would get you close and it’s called the convergence angle. It might show up on your OPUS sheet but I’m not sure, it’s been a while since I’ve done an OPUS.
   / Apps for land survey - Property lines #23
I've looked at a few around me and none of them make those kinds of mentions. They're all ...
... from a large oak tree along a field formerly owned by Jimmy John meandering generally westward along the Willie Lou property ...
Problem is, few people alive today remember Jimmy John or Willie Lou.
Yep, my deed references a road that has been moved, a creek, and the land of a bunch of guys who died in the 19th century.
   / Apps for land survey - Property lines #24
Thanks again. Yes Trimble is proud of their stuff but it just plain works. All of mine are the older R10 model 1's. I don't doubt the new ones cost that much. Mine were all ex rental units we bought used and we use TSC-3's. We upgraded to them from R8's just a couple years ago. I have never used the internal radios as we always use the external radios due to the distances we need to cover. We often put our main base radio antenna on top of the 30' extendable mast and then we have two other radios we use as repeaters.
I have never used VRS but the salesman demonstrated it to me at our shop. It looks slick. A lot of the places we work there is no cell service so I haven't really considered it but if I just worked around a metro area where it was available that is what I would use.
   / Apps for land survey - Property lines #25
We have spotty cell coverage also. The accuracy is a little worse with the VRS, especially the elevations. I think VRS is dependent on how close the bases are to your location. Illinois does not have a free VRS system so we are paying for the Trimble setup. A lot of states are free. Between U.S, Glonass, Galileo and the Chinese I am often tracking 22 satellites. When I first started using GPS over 20 years ago we were lucky to have 9.
   / Apps for land survey - Property lines #26
I just realized - I have photo editing software that can help find property corners. You MUST first have one established corner. Then dial in the direction and distance. It will get me within +or- five feet of the other corners. Continue on from there. Good for FINDING - I would not consider it accurate for survey.
Movavi Photo Editor 5 Pro
Ok Dodge Man (or anyone with experience)... the survey looks like a boundary survey... vs construction survey... what’s the difference... and can both be used 400 ft from nearest turn (corner marker)...?
   / Apps for land survey - Property lines #28
A big fabric or steel tape measure on a reel (at least 100' long) and a compass app on your phone should get you close enough to find the pins with the metal detector.
Aaron Z
Beware the HF cheap fabric 100 meter/330 ft tape. I use this for laying out replacement trees in the orchard, its ok for that. But going the width or length of the property with multiple runs of tape, forget it.
When the neighboring orchard alongside mine sold, I set a temporary flag where I expected the boundary was, knowing I only needed precision sufficient to distinguish which row of apple trees belonged on which side of the boundary. When that property was formally surveyed, my flag was within a few feet - close enough for my intended purpose but my adjustments for tape stretch and elevation change had left me certain I had not attained any precision. Rent a steel tape if you need reasonable accuracy.
   / Apps for land survey - Property lines #29
I haven't seen a mention of 'call all the survey firms in the vicinity'. One may have set some precise reference points at a defined distance from you.
In particular that new subdivision across the street from you likely still has monuments visible that you could start from.
I saw new survey monuments across the canyon behind me in a proposed vineyard. I called the surveyor and confirmed he had precisely defined my back line. I went over and nailed a marker - visible from my side - to a tree by my back corner. Soon the idiot owner there moved my informal marker to the bottom the canyon so his 4-wheeler trail would appear to be on his property. I went over and painted a foot wide white belt around the tree by the true corner marker. It took a couple of years to finally convince the neighbor to keep his 4-wheeler on his side of the property line, in the boring vineyard rows on his side of his new boundary fence.
   / Apps for land survey - Property lines #30
How accurate is it to find coordinates on Google Earth for a specific corner, then use a phone's gps to go out with a metal detector to look for a pin there?
Tafe 45DI (A53317)
Tafe 45DI (A53317)
2014 GMC Sierra SLT Crew Cab Pickup Truck (A59230)
2014 GMC Sierra...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2009 1770 NT 16R Planter (A59814)
2009 1770 NT 16R...
Toro MBTX-2500 Concrete Buggy (A54865)
Toro MBTX-2500...
