ARC Fault Breakers. Your Experiences.
   / ARC Fault Breakers. Your Experiences. #101
I am building a load shedding system which is in a cabinet adjacent to my load center. I have to run my heating circuits into this new box. But if the wires are not long enough and you can't make connections inside the load center cabinet, sp what is a guy supposed to do? Can you solder connections or something to make them compliant?
I can't find a reference to the CEC, but it is fairly closely aligned to the NEC used by our neighbours to the south. From what these references say, it is legal to make splices in a circuit breaker enclosure.
Splices Permitted in Panel Enclosure, NEC 211 - 312.8 (2min:47sec) - YouTube
Wire splices in panelboards -
Mike Holt's Forum
Code Quandaries | EC&M
Chris
(A pet peeve of mine - it's in everyone's best interest if people follow the NEC (in America) or CEC (in Canada). Fewer people will be killed and less taxpayer money spent on fighting fires. Our federal governments should subsidize their production so that the NEC and CEC are available free of charge to everyone.)
The printed rules are often difficult to interpret. And inspectors all have their own take on it and often their own ideas of what they want and don't want to see.
Places like home Depot sold books makeing it easy to understand the code but things like splices in load center enclosures likely are not mentioned.
   / ARC Fault Breakers. Your Experiences. #103
AFCI and GFCI are not for use on smoke detectors circuits , sump pump circuits , home heating/cooling circuits and on fridges/freezers .
   / ARC Fault Breakers. Your Experiences. #104
agree whole heartily...but the code says different. says EVERY residential 120 circuit that is not GFCI protected shall be arc fault protected...but not in my house..EVER
   / ARC Fault Breakers. Your Experiences. #105
Canadian Electrical Code allows exemptions for kitchen fridge, some smoke detector applications and sump pumps.
   / ARC Fault Breakers. Your Experiences. #106
did not know that . as far as i know, the NEC does not. Idaho has not (so far) enforced the arc fault requirement for entire house, but Washington state has. were probably not too far behind
Funny that they admit how useless and unreliable they are.
   / ARC Fault Breakers. Your Experiences. #108
Canadian Electrical Code allows exemptions for kitchen fridge, some smoke detector applications and sump pumps.[/QUO
Could that all be about (unreliability) nuisance trips?
Yah think?
Case Axial-Flow Combine Wheels NO RESERVE (A55301)
Case Axial-Flow...
Ford Pickup NR (A50323)
Ford Pickup NR...
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
2020 BOBCAT T76 R SERIES SKID STEER (A52705)
2020 BOBCAT T76 R...
Utility Trailer (A52377)
Utility Trailer...
