mbohuntr
Platinum Member
I hate to correct anyone, but in reality the electronics driving the LESs are quite efficient and need little or no heat sinking. It is the LED that generates most of the heat. Typical LEDs have 15-20% luminous efficiency. So if you take the wattage of the light, 80-85% of that is dissipated as heat. Nearly all of the cooling requirements are for the LED(s).
paul
Not taking any offence, The heat sink encompasses the LED DRIVER containing the mip552 which is only rated for 75 deg. F. The driver in this light circuit is switching at 44khz. Power transistors can get VERY hot! An IGBT working as a variable frequency drive needs and is entombed in its own dedicated cooling system.
While I stated that the power transistor can get very hot and requires a heat sink, I never said it was a large heat source, only perhaps the hottest temperature wise, and the part that needs cooling to protect the LEDs as stated in the IEEE article.
http://m.eet.com/media/1124374/10640-figure_4.pdf
The Subtle Circuitry Behind LED Lighting - IEEE Spectrum
