Are there any mechanics that work on foton tractors having fuel related problems that I can't figure I'm near Cleveland Ohio
   / Are there any mechanics that work on foton tractors having fuel related problems that I can't figure I'm near Cleveland Ohio #21
Just to clarify.
There is a pressure relief valve in the IP that keeps incoming fuel to about 40 to 55 PSI?
I had it tweaked a bit. I have a 30 psig Murphy fuel pressure gauge installed between the secondary filter and the injection pump with the alarm set at 5 psig.
This valve was failing and dumping pressure in the 15# range until you replaced it?
Yes, actually less.
In the first video, as the engine rev'ed up, was the IP actually drawing fuel faster than the lift pump could provide it.
Not so much in volume, but in pressure. The cavity is relatively small.
IP pumps seem to be simple yet finicky.
Yep, especially if the valves and seats get pitted from "bugs" like mine did. It would barely pump. And then there is the internal leakage issue.
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A52377)
2012 Chevrolet...
2019 UTILITY 53X102 REEFER TRAILER (A52576)
2019 UTILITY...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A52472)
2013 3400QB...
2013 Doosan Light Tower (A51573)
2013 Doosan Light...
