Are there kits to raise 3-point lift arm connection points?
   / Are there kits to raise 3-point lift arm connection points? #1
bobmart
Rio Rancho, New Mexico
Kubota L2501 4wd with quick attach, former Kubota L3800 HST 4WD stolen
I have a L3800 Kubota and wish to purchase a used rigid shank cultivator, Model 13-1 made by Dearborn for Ford tractors. However, the holes for the pins for the lift arms are 24 inches above ground, and my highest "up" position on the Kubota 3-point hitch is 27.5 inches above ground. The Chisel points would only be 3.5 inches above ground, not enough clearance to go up the ramp on my 16-foot bobtail car hauler trailer or my PJ dump trailer. Does someone make a riser attachment for the linkage on 3-point hitches, or is there another solution? I love that old cultivator, but can't buy it if I can't get the tractor on and off the trailers. I've only got 100 hours experience but have gotten good feedback from recent custom tractor work clients.
   / Are there kits to raise 3-point lift arm connection points? #2
I have a L3800 Kubota and wish to purchase a used rigid shank cultivator, Model 13-1 made by Dearborn for Ford tractors. However, the holes for the pins for the lift arms are 24 inches above ground, and my highest "up" position on the Kubota 3-point hitch is 27.5 inches above ground. The Chisel points would only be 3.5 inches above ground, not enough clearance to go up the ramp on by 16-foot bobtail car hauler trailer or my PJ dump trailer. Does someone make a riser attachment for the linkage on 3-point hitches, or is there another solution? I love that old cultivator, but can't buy it if I can't get the tractor on and off the trailers. I've only got 100 hours experience but have gotten good feedback from recent custom tractor work clients.
I had similar problems with my MX5100 and various implements. Kubota's range of motion in the lift arms are not as wide as other brands, such as Deere even in the bigger tractors like my M7060. Anyway, behind the MX, it would pick up a 3 point disk harrow high enough to even turn in some cases much less go in and out of low areas. I looked at options of trying to modify the lift arms on the tractor, but trying to get them to come up higher would cause them to hit others components on the tractor (axle or diff housings). Another option was to get longer arms, which will make the range of motion wider and the up height taller, but also moves the implement further back. I ended up modifying the pins on the disk, moving them down lower so that it would be lifted higher in the air when behind the tractor.
   / Are there kits to raise 3-point lift arm connection points? #3
I put these (http://carterandsonsllc.com/) on my L3400 to make connecting implements easier, as it doesn't have telescoping links. Raising the connection height was a bonus. Also, for tall implements on my short tractor, I have a hydraulic top link, which lets me tilt the top of the implement quite a ways towards the tractor. Makes trailering easier.
   / Are there kits to raise 3-point lift arm connection points? #4
Have you tried putting the top link in the bottom pin location on the tractor? This should get you several inches for transport height. Or get a hydraulic top link as mentioned in post #3 and all these height issues usually go away. :thumbsup:
Until you posted and I looked at the tractor again I didn't realize there were top and bottom pin locations for the top link. Its currently in the bottom pin location. I really am a newbie, but challenging yourself and taking on new assignments is the way you learn.
   / Are there kits to raise 3-point lift arm connection points? #6
1. The STIRRUPS at the foot of the LIFTING RODS have two pin adjustments, HIGHER/LOWER. When the Lower Links are pinned higher in the stirrups you will have more lift. (Lower is the default position.)
2. You can move right and left LIFTING RODS in along the Lower Links to alternate holes closer to the tractor. You will lift higher but have less weight lift capacity. (Out is the default position.)
MTVIEWRANCH's solution is easier, if it gives you enough lift.
These adjustment features are all part of Harry Ferguson's original design for the tractor Three Point Hitch, circa 1936.
Adjustments were to fit different plows with varying plow depth parameters, to more than a single tractor.
TBN ARCHIVE LINK: http://www.tractorbynet.com/forums/kubota-owning-operating/264107-lower-link-arm-adjustment.html
   / Are there kits to raise 3-point lift arm connection points? #7
I was given a John Deere 506 mower ( I know lucky me) I couldn't lift it high enough to suit me so I just did what an earlier poster did. I drilled new holes in the mower brackets and lowered the bottom pins. I can easily lift it high enough now. Good Luck
Thanks for the help. I found the stirrups on the lift arms and the closer in and further out holes. I will measure top and bottom travel positions in both hole positions with my box blade attached tomorrow morning. This forum is great. While I like the old Dearborn rigid cultivator, a lot of my motivation for buying it is due to the difficulty of attaching my Landpride PTO driven rototiller. It does a great job but is a real ***** to attach.
Thanks for the help. I would have to weld on lower arm extensions, but its do-able.
   / Are there kits to raise 3-point lift arm connection points? #10
I would work more on getting the hang of hooking up the rototiller, each time you hook it up the next time is easier.What is so hard about hooking it up?
   / Are there kits to raise 3-point lift arm connection points? #11
*** X 2 ***
Most of us shared your struggle mounting implements and CONNECTING PTO SHAFTS as new tractor owners.
Land Pride is practically a captive Kubota supplier. Your roto-tiller should mount on your L3800 Three Point Hitch without modification to tractor nor implement.
Does it appear you have the original Kubota Top Link?
Is there a storage stand on the implement which you need to reposition out of the way?
The L3800 has a standard Category 1 (size) Three Point Hitch.
What size/model number is your Land Pride tiller?
Does tiller have a matching Category 1 (size) Three Point Hitch or a Category 0 (smaller), or Category 2 (larger) Three Point Hitch?
[There are also Category 3 and Category 4 Three Point Hitches for huge tractors.]
   / Are there kits to raise 3-point lift arm connection points? #12
I should probably look at my Kubota before posting this but anyway, my recollection is that the rocker arms (those two heavy forgings that lift the sidelinks, which in turn, lift the lower arms) are mounted to their tractor's attachment points behind the seat, with a fine toothed spline. Remounting the rocker arms to their attachment points but with the rocker arms rotated down a spline tooth or so should shift the entire linkage's range of motion upward by whatever that remounting angle change was. So now it lifts higher but can't reach down as low. (My other recollection is that the linkage always reaches lower that my implements need it to anyway so that sacrifice is not a problem)
If that solution works, I'd lift it very slowly the first time, watching for interference or linkage binding.
   / Are there kits to raise 3-point lift arm connection points? #13
I built a platform out of wood with 4 casters for my heavy 3pt rear snow blower. It helps the process of attaching it. I haven't done the same for my tiller but should.
You might consider that for your tiller.
   / Are there kits to raise 3-point lift arm connection points? #14
bobmart:
You might want to get a "Pat's Quick Hitch", especially for your tiller. It works for everything else too.
I have a King Kutter tiller that weighs 690 lbs. The Pat's Quick Hitch makes it SO easy.
You can buy a "Pat's" from Agri Supply, or here on TBN.
Read the reviews on the "Pat's". I think you will like what you read.
At first it was a problem of lining up the lower link arms and the order in which the driveshaft was connected. I also had a problem with getting the rototiller to roll forward to connect the top link. What used to take me an hour is now about 15 to 20 minutes. Still unacceptable when out at a client's property. I found it helpful to block the skidplates at the bottom of the tiller to enable the tiller to roll forward to line up the top link. I'm sure repetition will decrease my hookup time.
   / Are there kits to raise 3-point lift arm connection points? #16
How much did you pay for those?
KIVEL 48" PALLET FORKS 3500 LB CAP (A60430)
KIVEL 48" PALLET...
24017 (A56859)
24017 (A56859)
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A60429)
2021 CATERPILLAR...
UNUSED FUTURE P45-56" MINI HYD BREAKER HAMMER (A60432)
UNUSED FUTURE...
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
