At Home In The Woods
   / At Home In The Woods #631
Have read about the last thirty pages today as I stumbled on this thread. First rest assured the Advanteck subfloor is doing fine without any further concern. It is able to handle all you throw at it and more without failure. We used it recently on my 1200 sq' addition and on my new 40d x30'wide two story barn. We also used their 'zip' roofing system on both structures and it is better than standard roofing underlayment for numerous reasons.
We had rain and snow from mid-March through to roof close in on the addition and no warpage of sub-floor. We had monsoon season here in VT most of the spring and summer through the fall season. So much water that we had to dig a 14' deep curtain drain in behind the barn perimeter to keep water away from the foundation! :eek:
Even the excavator said he's never seen anything like it in all the years of doing excavation/ foundation work.{ I do have LOTS of upland springs that provide the water that nature adds to when she feels like it} :eek:
I'd like to suggest using 1' blueboard around the entire perimeter and then taping it to seal out drafts. Then apply Hardiboard siding to finish it off with the nicest look you can possibly imagine. Use Kleer brand corner boards and rake/trim, it is 100% PVC and cannot be bothered by water, termites, ants, sunfade etc. For decks use Azek with their hidden fastener screws with insertable caps to make for a flawless look with no screwheads visible and no overpriced under deck fastening system. We used it around the addition and near the hot tub and did a diagonal pattern over PT framing. We used a piece in front of the diagonal for framing out the diagonal sections and we put it tight together so it is easy to hose off or sweep off and no place for leaves to get stuck between boards. Its not cheap, and neither is Kleer but they are the best products for maintenance free outdoor projects. Do it once and do it right the first time for my money. I don't want to have to paint, stain, or repair anything on the exterior for a VERY long time if ever!:D
As to whole house fans or what are now referred to as ERV- Energy Recovery Ventilators, Panasonic makes one that we are installing in the barn apartment. It has twin 4' connectors that run to a "y" connector which exits the exterior wall as a single hole and the interior of the tube is split so both intake and exhaust will enter through the same pipe and branch off, so as to not mix the intake and exhaust air. Panasonic is on top of the list as to bath and kitchen fans. They are super quiet, can combine fan, light, heat and nite light and sometimes you can get as I did open box units from trade shows that have little of no actual use on them for substantially less $ than retail price new in box units. I have 8, that's eight of them between my house/barn in VT and two houses in CT. I put the heat and fan on timers and everything else is on decora type switches. I do NOT use the nite lite feature, and put the fan and two 13 watt fluorescent bulbs on the same switch for convenience.
I buy from waveplumbing.com and they have been great. (I have no affiliation with them whatsoever).
THE ERV is used due to tight insulation and I do not want interior moisture problems due to it. In the house in VT and in CT I have also installed two whole house fan units that ran about 700 or so as I remember it. These are in place of air conditioning and are used exclusively in summer fall, never in winter. I got them from a place in California; I can't think of the specific brand or 'store' at this moment in time. They are installed between attic joists and work in conjunction with an uninsulated dead air space above the attic floor pulling cool air from the first floor open window(s) in the evening/night to allow cool air to push hot air out the gable end vents and to draw air from the soffit vents as well to cool the roof and upper structure from heat accumulation that occurs on hot days. They work really well and cost a fraction of what a central air system would. One word of caution, if you have things like gas appliances with pilot lights you should contact a professional certified gas installer to access whether to use them in that situation.
Place looks good, try to not sweat too much on the details beyond making sure things fit as intended- try to put some trust in the overall process. I know what its like to act as my own GC and oversee the actual GC on site. We collaborate on all things and some things I find in hindsight that I was loosing sleep over are not as big a deal as I thought they were at the time I was obsessing over them in the moment. I'm obsessive to a fault so I know what the ups and downs you refer to are like. Try to enjoy the ride/journey, in the end its only a house, not the end of the world as we know it. Take a step back once in a while. Go away if you can with your wife for a weekend and come back to a renewed view and perspective to being up close and personal with the project every day. It can be stress relieving. Ask me how I know?:)
   / At Home In The Woods #632
Re- your eviction.
You probably wouldn't have that trouble if:
A) You hadn't cleared off the lot so nicely. Merely cleaning it up enough to get the trailer in there wouldn't have exposed you to view so easily.
or
B) You and Mrs were a couple of illegal Mexican bean pickers holed up in there.
But that's just me.
You've shattered my image of the South as being a place where people are more free to do as they see fit to get by.
Up here (New England), snob zoning rules are the norm.
I found out something that sort of goes hand-in-hand with something Eddie said:
Most towns are quite selective in their enforcement of zoning rules, usually bowing to the demands of those they fear will cause them big legal headaches, whether those folks are the ones complaining or the ones offending.
I've been through it myself, and it always makes me laugh when people think they're ensuring sustained property value and material happiness when they pass stricter zoning laws.
It always seems to come down to the question: "How much justice can you afford?"
   / At Home In The Woods #633
I won!!! It was zoning. Oh well, zoning is taking over our world. Here where I live in rural Alabama the county passed a new zoning ordinance. You can't "subdivide" a piece of land into over 3 parcels and received addresses. The problem is they didn't specify the size of the piece of land. Doesn't matter if it's 2 acres or 200.
Chris
Have read about the last thirty pages today as I stumbled on this thread...
Coyote, thanks for the thoughtful response. Great comments and suggestions.
Obed
   / At Home In The Woods #635
Talking about stupid zoning laws. Here in my county you can not build a home on a lot with any less than 300' of road frontage. Well my neighbor inherited a piece of property that is 11 acres and had be divided by his family many years ago from a 55 acre tract. 3 pieces of the tracts have home on them but guess what? His land has 297' of road frontage. 3' shy of the requirement. He filed for a waiver with the county and they made him post his intentions in the paper and on a sign on the property for 30 days prior to the hearing. A non family member neighbor got a lawyer and fought it. Guess who won? Yep, the A-hole neighbor. Now he has a piece of land that is worthless. He plans on putting hogs on the land this spring even though he is not a farmer. The guy wants to buy the land cheap so he can keep his place far away from other homes. Now he gets hogs instead of a nice family who would have built a beautiful home.
Chris
   / At Home In The Woods #636
Sounds about right. I've got a friend that runs a wreck business and "pull a part". His neighbor (that moved in) kept reporting him to the EPA. He was following all guidelines by removing all fluids from the cars etc... when they arrived.
Finally the EPA guy got tired of coming out and suggested that my friend get some hogs and put them in the salvage yard with the cars. He converted an old school bus to a shelter.
You got it. The neighbor called the EPA about the hogs. The inspector that came out (same one) finally told the neighbor to quit harrassing my friend and to not call back.
Hey Obed, Any progress????
Chris
   / At Home In The Woods #637
Chris
Maybe your friend could talk one of the adjacent property owners into selling him a 3' X 1' piece of land so he could meet the 300' frontage requirement.
We built a house for a guy that wanted the house set back farther than his existing pole barn. County regs prohibited that arrangement unless the property was zoned ag. The only thing the owner had to do to change zoning from rural estates to ag was buy 5 more acres. He bought the 5 acres from the farmer behind him. The county went ahead and ok'd his permit, then had to reimburse the owner the permit fees because building permits for improvements on ag zoned property are free in our county. Once the house was done and we got the occupancy permit he sold the 5 acres back to the farmer. The money saved on the permit more than covered the expense of dealing with the zoning issue. The county would have been money ahead to give the owner a variance but thats not how our county does things.
For many years our county had a 250' minimum frontage requirement......and a 400' between driveways requirement. They eventually dropped those requirements and now requires a minimum lot size of 10 acres outside city limits. They wanted to make it 20 acres minimum. They flat out said they don't want people living in the country.
I've been impressed with our truss designer. He seems very knowledgeable and competent. He used to do framing work. Last week I worked out an arrangement with the floor truss designer to design our stick built roofs. The truss designer met with my wife and the framer yesterday. He gave us drawings and talked with the framer about how the roofs should be built. My wife said the meeting went well.
   / At Home In The Woods #639
I think that was a wise move.
So how is construction progressing?
Pops
   / At Home In The Woods #640
This is a new one for me. Was this always part of the plan? or did you decide to call in an engineer to help your framer do his job? roofs are fairly simple. Once you've done a dozen of them, give or take, there's not much more to it. The biggest issue is slopy cuts on your angles, but again, most guys have it down fairly quickly.
Am I reading too much between the lines here?
Eddie
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2018 Ford F-150...
2017 Chevrolet Ambulance (A55973)
2017 Chevrolet...
2015 Chevrolet Silverado 1500 Pickup Truck (A53422)
2015 Chevrolet...
2016 NISSAN VERSA Sedan (A53424)
2016 NISSAN VERSA...
Rooster Weathervane (A55853)
Rooster...
2022 Cub Cadet Ultima ZT1 54in Zero Turn Mower (A55851)
2022 Cub Cadet...
