At Home In The Woods
   / At Home In The Woods #1,401
Shower Update
Our plumber told us that if we replaced the shower/tub, most of his plumbing would have to be redone. He says he has seen fiberglass tub repairs that were done so well that you couldn't tell the tub had been repaired. The plumbing supply store that sold us the shower gave as a number of someone who repairs fiberglass tubs. The wife talked to them. It will cost $95+ for the repair. We are most likely going to get the tub repaired instead of replacing it.
Even if the repair is not perfect, I don't think it will bother me, mostly because I like this framer and it was an honest mistake. It's kind of strange but if the original CM/framer had damaged the tub, I think I would have been forever annoyed every time I looked at the tub. Go figure.
Probably a wise choice. We had a white fiberglass tub repaired one time, you could not tell.
Russ
   / At Home In The Woods #1,402
Obed,
Regarding "metal" boxes and exterior brick veneer, does your electrician have an opinion about the cast aluminum (I think) boxes found next to the weather-tight receptacle covers at the big box stores? I have used these boxes for exterior receptacles that are recessed in log siding. They seem to work just fine and do not rust. Electrical shorting and safety are not issues if wiring is done properly and the boxes are grounded per code.
Have fun :).
- LogChain
   / At Home In The Woods #1,403
If you go plastic, make sure it's the "heavy duty" ones. If you check out plastic boxes at the big box stores, you can see the difference. The problem with the cheap ones is the plastic where the screw goes in is not very thick and easily breaks. Put some light oil on the screw and in the hole so it doesn't rust and become impossible to remove.
Aluminum or die cast zinc would be OK too. I'd hit the screw hole and screw with some light oil to keep it from seizing.
You might also try to get some stainless #6 screws to change out for the ones supplied with the outlet so that you won't have corrosion problems down the road.
Pete
   / At Home In The Woods #1,404
For such a small amount of money, I can't imagine why anybody would use blue, interior, boxes on exterior walls?
Tub repairs are fairly common in new construction and I've never been able to tell where it's been done on the jobs I've been on. I've never seen it as bad as that, so I can't say how the repair will look. In my experience, the damage has been from something dropping on the tub and chipping it.
Good luck, the house is coming along nicely.
Eddie
   / At Home In The Woods #1,405
Carlon "Super Blue" boxes are a heavy duty version of the plastic boxes mentioned above. I have used these and like them.
Make sure the electrician or someone seals and or adds flashing tape to the boxes to prevent leaks and wind infiltration. I pulled a front entry door before trying to find a leak, before realizing it was coming from the convenience receptacle next to the door.
I have seen a box with flashing tape of some sort already attached, but do not remember who manufactures it.
   / At Home In The Woods #1,406
The presealed boxes are code up here in Minn. Carlon makes them, for one, and you can get them anywhere up here.
Technically the Minn energy code requires boxes in exterior walls to be sealed from air infiltration. There are several ways to get there, and pre-sealed boxes are only one way. They have foam tape over the wire access holes that you poke a wire through. They conform to the wire, but not perfectly. The other holes remain sealed so you get a pretty good total seal. In this case, if you use a bottom hole for wire access, any water would tend to drain out and not in. Another common sense precaution would be to loop the wire up from below so water doesn't run down it into the box.
-Dave
Eviction Notice Again!
attachment.php
The beaurocrats found us. We have 60 days to move out of our camper or face a $500/day fine. We will not be ready to move in the house in 60 days.
attachment.php
The code officer who served the notice listed R2 (residential) zoning to back up the notice. I told her that we are zoned A2 (agricultural). She said it didn't matter, that we couldn't live here on A2 zoning either.
Yesterday we had our rough-in inspection and electrical inspection. I suspect one of the inspectors turned us in.
   / At Home In The Woods #1,408
I think it is an office trailer just my opinion that you let the baby sleep in :D
good luck
tom
   / At Home In The Woods #1,409
Obed - If it wasn't for bad luck you wouldn't have no luck at all. :)
That is total BS at this stage of building. They should have inspected the property when you applied for a building permit. Check with a lawyer and tie it up in appeals at the worse scenario. By then maybe the house will be done.
Good luck.
   / At Home In The Woods #1,410
Good luck.
If you check with a lawyer, make sure he's a "land use attorney". They should know the zoning laws inside and out.
2020 Freightliner Derrick Digger Truck (A55973)
2020 Freightliner...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A56436)
Koyker Loader...
2018 CATERPILLAR 12M3 MOTORGRADER (A52709)
2018 CATERPILLAR...
23091 (A55758)
23091 (A55758)
2018 HINO 338 KNUCKLE BOOM TRUCK (A51406)
2018 HINO 338...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
