At what pressure to replace mig gas bottle
   / At what pressure to replace mig gas bottle #1
kencunningham
I am just about thru the first bottle on my HH 190. This is the first time using gas, and was wondering at what pressure i should switch it out.
   / At what pressure to replace mig gas bottle #2
Shrug,
Before I obtained a second bottle I would wait until I'd be worried about running out in the middle of a doing something.
By now you should have a bit of a feel for how much you're using. Are you getting nervous? Change it out or buy another bottle. What do they need for a bottle these days? The last I knew they wanted around 50 bucks to own a small bottle plus whatever gas you needed.
Do you trust your gauge reading?
I have 2 bottles, i was looking for other peoples experience to help me decide how low to let the pressure go before swapping it out.
   / At what pressure to replace mig gas bottle #4
On my Mig gas I run it down until the working pressure starts to drop. I run between 15 to 20-cfh.
On my argon bottle for Tig welding if I'm doing aluminum work I'll switch bottles sooner. For some reason when doing aluminum Tig work, soon as the bottle gets close to empty it affects the weld.
   / At what pressure to replace mig gas bottle #5
I run mine down until I start to see porosity (bubbles) in the weld with my 75/25.
I have a CO2 back up bottle (soft drink tank) that I will use to keep going.
For me it's 2 hours round trip for a fill so I have to plan the trip.
   / At what pressure to replace mig gas bottle #6
Agreed if you have two bottles you do not need to change it before it won't weld right. You will know right away.
   / At what pressure to replace mig gas bottle #7
I run it till it's empty..especially if I am doing it on my dime. You can stop once in a while to readjust the regulator if need be if it's running it's last gasps...unless it's a super critical weld.
   / At what pressure to replace mig gas bottle #8
How big are your cylinders? Running it till empty means you'll probably have to grind out a bad weld and if you don't completely grind all the weld out, you'll get porosity and have to grind it out again. Depending on the weld could be a real PIA. Run it down to around 40 PSI or so and you shouldn't have to worry about a bad weld. 40 PSI is a lot more gas in a big cylinder than a small cylinder. Adjusting the regulator may or may not do anything but I've seen a few people turn their oxygen or acetylene up trying to get more gas from an empty cylinder and then forget to turn it back down when they get a new cylinder. This can be dangerous and/or waste a lot of gas. It's always best to loosen off the regulators every time but on a flowmeter/flowgauge, it's very rare to back off the adjuster.
Both of the cylinders are 40cf. After seeing the responses, I'll only let it go down to 50 psi at the lowest.
   / At what pressure to replace mig gas bottle #10
50 psi will get you a lot further than you think. You do not need to worry about you the psi in the tank until you see that the tank will no longer produce the pressure to desired CFM you set. Once you have used a few tanks you will know, roughly, how big a job you can do with what psi you have in the tank. I have two tanks. I ran out once, on a saturday, (the gauge was not working properly) and I will never do it again.
   / At what pressure to replace mig gas bottle #12
I usually run out of shielding gas the same way I run out of wire - by surprise :D
But that's why I have a backup CO2 bottle and stick/tig welders - because I know I get working and forget to check stuff :ashamed:
Usually when I run out, I instantly remember that the last time I said "gotta buy some wire next time I'm in town."
   / At what pressure to replace mig gas bottle #13
I just watch the CFMs. I notice the tank gauge, and when it gets low I just watch the flow gauge and when it starts falling from where I set it I replace. I run the #4 size cylinder from TSC and just weld for myself.
On gas, it's amazing how long they last once you get the leaks out of the hookup.
Mark
2396 (A60432)
2396 (A60432)
Willmar 4550 Wrangler Articulating Loader (A61306)
Willmar 4550...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
2014 Chrysler 200 Sedan (A59231)
2014 Chrysler 200...
2014 Freightliner Bucket Truck (A56438)
2014 Freightliner...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
