Attachment for mowing a pond waterline....
   / Attachment for mowing a pond waterline....
Got the mower "pallet" done last night. Originally I was going to use two square tubes per side to hold the mower and the counter weights, but I am going to try it first with just one and see how it does. I'll add the other if it's not stable enough.
I angled the edges of the CarryAll so I can tilt the hyd toplink and back under the "pallet" like a forklift (that's the idea anyway). The tabs on the front of the "pallet" have 1/2" holes so I can drop a pin through to keep it from wanting to slide off when in use.
I am thinking of adding 2x10's on the headboard of the CarryAll. Then making a "floor pallet" with 2x10's mounted on it. That would allow the CarryAll to be used as a CarryAll, or drop the "floor pallet" and pick up the "mower pallet" when it's grass cutting time. This opens up the ability to make other "pallets" for other uses.....though I can't think of any right off.
I got some "Machinery Grey" paint at Tractor Supply, it's not even a close match to Kubota Gray, but I don't think I want to paint everything I make with that $11 a can Kubota Paint.
Took the mower out for a test run last night. I wanted to see how it would work with just one stick of the square tube instead of two per side. It did fine, so I am going to leave it with just one. It DOES however need counter weight for sure. Also, I found it needs a gage wheel I think - and some skirting around the deck to keep from launching rocks. I hope to finish up tonight and hopefully get paint started. I'll post some more pics tomorrow.
   / Attachment for mowing a pond waterline.... #73
It looks good, and I bet you DO need some skirting like they have on brush hogs, are you thinking rubber flaps or chain? Guage wheels make good sense too, or scalping will be a regular thing.
Thomas
Sorry guys, didn't realize I hadn't updated this build thread.
I did end up finishing the mower and using it serveral times before the grass stopped growing. It worked out good - doing the job it was intended to do, but I found that it was just too long, heavy and clunky to use for what I wanted.
I cut it up this past weekend to use the steel while making a set of brush forks. I have another idea I am going to explore - mounting the mower engine in the center on the quick hitch, replace the mower blade with a pulley, then have an arm that swings to each side and locks in place with a pin. At the end of that arm would be a weedeater head connected to another pulley and belt driven. I could make the arm telescopic to reduce the length when put away between uses.
   / Attachment for mowing a pond waterline.... #75
Maybe a float on either side would let you get all the way to the edge and even weeds in the pond itself? Like the ones in your last two photos.
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
Kubota BX2380 (A50120)
NAMCO GRAIN-O-VATOR GRAIN WAGON (A51243)
NAMCO...
Land Honor Skid Steer Blank Plate (A50514)
Land Honor Skid...
2013 Dodge Grand Caravan SE Van (A50324)
2013 Dodge Grand...
