Attachment puzzle to me
   / Attachment puzzle to me #11
good to use cleaning around shelter belts.
   / Attachment puzzle to me #12
I was going to say a tiller converted to a sheepsfoot roller (used to compress road sub-base) except - that drive shaft would spin it too fast so that's not the answer.
Top welded pieces had at some point sharp edge. So this was definitely made to break/cut something. The 2nd owner never used it but it was definitely used long time ago as they are dull and worn out.
Since nobody has another pic like this I am definitely interested in trying this thing out in the spring - lol.
   / Attachment puzzle to me #15
Your 3 picture would indicate that originally it was a tiller. However that is no longer the case. It looks as those someone has modified it at some point. Depending on its rotation direction, the ‘hammers’ on it will either do a rough rip of sod/grass/weeds or hard soil, or more of a compaction of loose soil.
Check the gear oil levels in the gear box and chain drive or gear drive on the side and see what results you get running it. Preferably in an area that does not matter to you.
I agree with you. It used to be tiller.
Yeah, now it's just too cold here to do the needed check on fluids etc but spring comes I have lots of bush/ swampy area to try it on
   / Attachment puzzle to me #17
As strange as life is, I was looking on fb marketplace a few minutes ago. In the Winston Salem area a Howard Rotovator J is listed.
I can't search that are from Canada. If you paste a link I might be able to see it. I have found quite a few J style , just not like the one I have
   / Attachment puzzle to me #19
I would think you could search CL from Canada. It's just a web page. Just like I can search kaja or whatever y'all's equivalent is? Haha
   / Attachment puzzle to me #20
Here you go!
craigslist: best-of-craigslist :D The listing from early May is a classic.
But try this SearchTempest which combines local CL postings, over a region. This one is set to find backhoes within 300 miles of SF airport. Edit as needed. Click on 'cities' when you have it tuned the way you want it. I'm interested to hear if it includes Canada.
backhoe -bobcat -skidsteer on SearchTempest
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56435)
Neckover GL24-2-7K...
2016 Komatsu WA380-8 Wheel Loader, S/N 15080, PIN# KMTWA13OCGA015080, Turbo Diesel Engine, Komatsu (A59076)
2016 Komatsu...
2019 Ford F-350 4x4 Flatbed Truck (A55788)
2019 Ford F-350...
2015 DRAGON 130 BBL STEEL VACUUM TRAILER (A58214)
2015 DRAGON 130...
CAT 312C EXCAVATOR (A58214)
CAT 312C EXCAVATOR...
