Attachment to turn grass to dirt...
   / Attachment to turn grass to dirt... #11
Nothing to it really. If you have a lot of rocks, the Harley rake is going to work better than the other two. If not many rocks, either the disc or tiller will work. Kill the grass first. If you don't, you will have ground-up sod that will try to regrow. If you don't kill the grass, at least mow it short to help stop regrowth. The tiller set to just a couple inches deep will give you a dirt track in 2 passes. The disc harrow will take a few passes depending on disc model, setup and weight.
   / Attachment to turn grass to dirt... #12
A pic would help us determine how to approach
   / Attachment to turn grass to dirt... #13
The RoundUp suggestion is a good one. Now that RoundUp is off-patent, the generic versions of glyphosate might be a bit cheaper and just as effective. Don't spray on a windy or rainy day if you care about effectiveness with minimal collateral damage.
   / Attachment to turn grass to dirt... #15
Old thread but curious to your outcome. I am looking to attack the same thing in my yard.
2006 JCB 520 Telehandler (A59213)
2006 JCB 520...
5-6 YD BLUE LINE GRIZZLY SCREENER (A58214)
5-6 YD BLUE LINE...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
New/Unused SD Lanch SDLE20 Mini Excavator (A57453)
New/Unused SD...
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
