Attachments/Implements - I didn't know?
   / Attachments/Implements - I didn't know? #1
thcri
Elite Member
Minnesota SE
New Holland TC29D, 2001
Attachments/Implements - I didn\'t know?
Browsing through the Kioti page and clicked on products. I found a link for attachments and a link for implements.
When I click on attachments I find a loader and a backhoe.
When I click on implements I find aerators, box blades, brush hog, landscape rackes, tillers and so on.
So is an attachment something that has a permanent bracket but removeable such as the loader or backhoe and an implement is something you just hook on to your tractor and go?? I guess always thought there was really no difference.
murph
   / Attachments/Implements - I didn't know? #2
Re: Attachments/Implements - I didn\'t know?
I reckon a hoe could be both as there are 3pt and subframe mount for 3pt type. So I don't know if that's actually a rule. What about a cutter? Think of that as an implement? Mount it to the front or side and it becomes an attachment. Implement for an attachment? Hmmmmm......
Then there are attachments for attachments.
   / Attachments/Implements - I didn't know? #3
Murph, I don't pretend to know the definitive difference, but every "implement" you mentioned can hook to essentially any tractor with a standard 3PH. The "attachments" all require a special adapter for mounting and are semi-permanently mounted.
I can't take a loader attachment off my New Holland and hook it to a Kioti without modification; however, I can take rotary cutter or boxblade and hook them to almost any brand of tractor with no modification. I think that's the difference.
   / Attachments/Implements - I didn't know? #4
Having done some editing for Kioti, I would simply guess that the only reason they have a difference is that someone suggested it sounded better.
John
   / Attachments/Implements - I didn't know? #5
THAT SOUNDS LIKE A VERY GOOD EXPLANITION /forums/images/graemlins/smile.gif Better than anything i could think of and it makes sense also. /forums/images/graemlins/grin.gif
   / Attachments/Implements - I didn't know? #6
I guess backhoe "implement" sounds kinda funny even though most modern are 3pt compatible. Just what we're used to I guess. Probably from the days when they mounted detachable ones to dozers and tlbs
2001 Pierce Spartan Model Tilt Pumper Fire Truck (A59230)
2001 Pierce...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
KBH Tender Trailer (A56438)
KBH Tender Trailer...
2009 CAROLINA  16FT EQUIPMENT TRAILER (A58018)
2009 CAROLINA...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A57880)
2012...
