ATV Trailer build
   / ATV Trailer build
Yea that MIGHT just kick it a little out the the budget. Tomorrow I will check out the neighbor's stuff. Was at another neighbors tonight, and he offered the same offer, so I have some possibilities. Might be just the angle iron I need and make my own brake. That will save a bundle.
   / ATV Trailer build #92
Going to post this in its own line but was perusing my popular mechanics last night before bed, and the subject of a metal brake is in the magazine. These guys are pushing the use of a Door as your brake. At first I laughed, but then it made sense.
   / ATV Trailer build #93
I have a small trailer that I floored with 3/4" pressure treated plywood. Works great. I stored it in the barn one season and it dried really well so I painted it. I keep the top surface painted now just to make it easier to clean.
You can get the PT plywood in different thicknesses too.
   / ATV Trailer build
Well I might end up with wood, but it's not by choice. Went looking over the neighbors stuff, and saw sheets of stainless, 14ga I think, but I will not ask him to part with that. That has to be a lots of $$. I am almost getting in the frame of mind to make it like the old pickup trucks, with the planks on the bed floor and sheet metal on the sides, BUT I am still in the same boat of getting the metal and having it bent.
I also need something to cover the end panels with, when I make those.
Today, I got the third coat of orange on the main frame, so hoping tomorrow to set it down and put the hubs on it, and roll it around a bit, just cause I can :). Still gonna keep my eyes peeled for some cheap sheet metal.
   / ATV Trailer build
On the other hand......I just thought of something. I have a bunch of clear doug fir floor boards that I took up from the floor of an old house we tore down when we built this one. The house was built in 1920 and the floor boards were original. That will work for the floor. They ar T&G but not sure if I want to keep that part, or trim it off. It would only trap anything dropped in there.
Still need to cover the sides and end panels.
   / ATV Trailer build #96
Any thought to use metal screen like the tow behind trailers I seen in Cabela's spring catalog?
It would definitely cut down on your trailer weight and you could always use something like cardboard to line the inside when filling with material that would fall thru screening.
PAGUY
   / ATV Trailer build #97
My local HD/Lowes have PT 1x's (3/4" actual) and "5/4" decking boards (1" actual). I would think either could work pretty well for a trailer. I have also picked up composite decking really cheap on a closeout (used it to redo a picnic table) and they often have short lengths of various 4' or so PT in the bargain bin.
I suspect fir won't last too long unless protected, but if you keep the trailer under cover and don't use it for wet things it might be OK.
If you have access to local roughsawn, white oak will last a while. 1x roughsawn (1" actual) could work really well.
My Dad built a trailer out of white oak, a car axle, and a 4' square x 1' tall metal cargo box he scrounged from somewhere. It had stake pockets, so with a stake in each corner if you stacked it right it could hold half a cord. The oak was soaked with used motor oil when the trailer was made, then used the heck out of it for 30 years with no further care. It was stored out in the elements, the most he would do was put a chunk of wood under the box (manual tilt) so the box wouldn't collect water. When he passed the oak frame was just starting to rot to the point where one would think about replacing it.
If you are worried about the dimension of the wood taking up cargo space, inset the wood into your frame. At each pipe, weld on chunks of 1" flat bar with mounting holes, so that when you bolt/screw on the wood, it's flush (or almost) with the pipe. The pipe would then help protect the wood from getting dinged up at the ends, too. If you wanted a tighter fit, you could bevel the wood ends where it buts against the pipe. You could also run the boards in the upper angled section of your frame up and down, instead of the long way, if you thought you didn't have enough support in that direction.
   / ATV Trailer build
Somehow missed this post in reading. I think it makes a lot of sense. I wonder how much you could get away with bending that way, and how accurate you could be. I don't need a 90* bend, just a 45, and I can live with a soft corner on that.
Paguy
I do something similar on my regular utility trailer, it's 4x8. It started life as a grape bin Ag trailer. I converted it to road use, and put heavy expanded metal on the sides. That EM is just as, if not heavier than 16ga would be. But I wanted strength there and was not concerned with weight. I use a tarp in the bed when hauling small stuff.
GLyford
If I had planned on wood I would have done it differently, but for now I have to deal with what I built. I don't really want to start cutting and welding on it at this point.
If I use wood, I will most likely coat it with some sort of acrylic or epoxy based clear coat, cause the trailer will spend most of it's time in the weather. Not enough storage room under cover, yet.
   / ATV Trailer build
Even though I shoot down a lot of idea that are brought, I want to be clear, that I really appreciate you guys spitting them out there.
   / ATV Trailer build #100
No worries, a lot of the answers amount to personal needs and style, and that's not something someone else can decide for you.
Every time I look through these builds, I see ideas and techniques that I can use later, even if it's too late on whatever my current project happens to be.
2018 Ford Fusion Sedan (A53424)
2018 Ford Fusion...
2015 Ford E-350 Cutaway Van (A55973)
2015 Ford E-350...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
Cushman Cart (A55853)
2014 Ford Escape (A50324)
2014 Ford Escape...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55302)
2012 RAM 5500...
