Treemonkey1000
Veteran Member
Scott you should have planted that IH hat at the bottom of the post instead of the top of it in your picture. Then be wearing the right kind of hat that say's Kubota on it.
Scott you should have planted that IH hat at the bottom of the post instead of the top of it in your picture. Then be wearing the right kind of hat that say's Kubota on it.![]()
if you have a nice loamy/sandy soil with minimal rocks, buy a PHD for your tractor and have at it. If your soil is heavy clay and rock....you might want to explore hiring someone with a bobcat mounted post hole digger.
Curious... If you justify buying a PHD and there are others that need fences or at least the holes dug, what would a guy charge per hole?
You are talking well over 300 holes. Buy one, and make sure you don't make the mistake of buying a six inch auger for 4x4s. It will make the job much harder than need be. Get a nine inch auger.
If your posts will be bigger than 4x4s, go up in size correspondingly.
My new speeco PHD is sitting outside on the ground in the box. I bought a 6" auger for digging 4x4 holes. Maybe I'm thankful it turned out cold because that gave me a chance to read TBN before I use it. Now my two questions are:
Why not a 6" to drill 4x4 holes.
And am I going to wish I'd have gotten a hydro one with reverse and how much that would cost.
The problem is that you will rarely drill a truly vertical hole and a 6" auger leaves little room to move the post around to plumb. The other problem is that once you get a 4x4 in a 6" hole there is little room left to get something in to tamp the dirt solid.
Hydraulic is great if you have the hydraulic outlets on your tractor to run it. You will also spend somewhere in the range of 4x more than a PTO driven unit.
MarkV
