Dargo
Super Member
- Joined
- Mar 6, 2004
- Messages
- 5,981
- Location
- S. IN
- Tractor
- Jinma, Foton, TYM, Belarus, Yanmar, Branson, Montana, Mahindra and maybe some green and orange too.
My newest tractor has a feature I'm not sure if I like or not. It's has mechanical front wheel assist (I call it 4X4, but I know that's not technically proper) that is selectable to "auto" 4X4 or full time 4X4 or regular 2 wheel drive. I mostly use 2 wheel drive. However, I discovered a feature I didn't know existed. I even looked it up in my manual to make sure it was a feature. What that feature is, is that the tractor automatically engauges the front wheels when you press the brake pedal and turn the steering wheel.
I honestly thought something was wrong with the tractor. It turns out that it is a safety feature. The JD rep I spoke with told me that the function is a safety feature that prevents an "out of control" trip down a hill with only the rear wheels sliding. Actually, it did exactly that the first time it engauged. I was mowing across the top of a lake dam and turned right to mow straight down the back side of the dam. The grass was a little wet and for a split second the tractor started to slide, then I saw the 4X4 light come on on the dash and felt the front wheels engauge. Once at the bottom of the hill it disengauged on it's own and I was back in 2 wheel drive.
My question is, do you guys think this is a good feature or a PITA feature? I'm not really sure myself. However, I don't think there is any way I can disable the feature. What's your take on the feature?
