AW32 vs. UTF?
/ AW32 vs. UTF? #1
azelgin
Ok, I have an old (1977) Ford 1000 with 770 loader with a seperate from transmission hydraulic system, that ended up with AW 32 fluid in it instead of UTF, or Ford compatable. Is there any reason this would be a problem? As far as I can recall, it has been in there for about three years and 300 hours. It blew a hose and AW 32 was what we had on hand for a refill. It seems to work as well, or better than it used to. The pump is quiet, it lifts as fast as it ever did and doesn't leak. Should I change it back to UTF? What's the worst that could happen, if I leave it alone?
Thanks for any ideas.
/ AW32 vs. UTF? #2
If the loader uses a seperate sump than the tractor.. then aw32 is fine.. though i persoanlly prefer to use UTF in most applications where plain hyd oil is used, when dealing with tractors.. etc..
soundguy
LOOK! (A63109)
LOOK! (A63109)
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
iDrive TDS-2010H...
2014 KUBOTA SVL75-2 SKID STEER (A64279)
2014 KUBOTA...
4000 GALLON METAL TANK (A63290)
4000 GALLON METAL...
(2) 28LX26 TIRES & RIMS (A63745)
(2) 28LX26 TIRES &...
