B-3030 lift arms
   / B-3030 lift arms #1
BlacknTan
Platinum Member
Adirondacks of NY
Kubota B-7800
Has anyone ever investigated the cost of swapping the extendable lift arms from a B-3030 to a B-7800 for the 3PH?
It must becheaper than a Quick-Hitch setup?
   / B-3030 lift arms #2
Sit down and hold on tight when you price these things!:eek:
I did look into doing this kind of swap, wanting to use the B2910 extendable lower arms and to adapt them to my BX...
Would have cost over $400 for parts alone...or was the $500 :confused:.
Crazy expensive... There have been past threads on this subject. You might find them with a search...
(edit: somehow this got posted while I was typing...
   / B-3030 lift arms #5
It ain't, nor is it as good as a QuickHitch (which $200 at your local TSC will get you)
B2910 (with extendable lower links), Speeco Cat1 QuickHitch
   / B-3030 lift arms #6
I think I'm going with Pats QH set up my self. My ballast drum is on and off my tractor a lot. It weighs over 800 pounds and if I don't back to it perfect and thread the needle just right it can try your patients. Its fine in the shop on a pallet jack but out on the ground its a pain
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A53472)
2000 Kenworth W900...
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
STORAGE FEES (A53426)
1269 (A50490)
1269 (A50490)
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2019 KENWORTH T680...
