B-7500 Won't crank. HELP
   / B-7500 Won't crank. HELP #21
Re: B-7500 Won\'t crank. HELP
<font color="blue"> Another thing,if the PTO is engaged before you start the tractor can you still start the tractor?
</font>
Nope. /forums/images/graemlins/blush.gif /forums/images/graemlins/tongue.gif
   / B-7500 Won't crank. HELP #22
That could be the problem but I won't know until I go back up there today. It seems that I might have hit the PTO lever as I was getting off the tractor. I hope so anyway.If that's not it I'm lost.I'll let you know this evening.
Donny /forums/images/graemlins/confused.gif
   / B-7500 Won't crank. HELP #23
Don,
Do what Bird suggested in his post above. This may solve your problem real quick.
And if that doesn't work, lay on the ground and look up under the tractor and you may find a broken wire or something stuck in where it should not be.
A lesson I learned sometime in the past is that you don't always have to understand how something works to fix it.
For example, if you look around and find something like a wire broken off, and can see where it came from, and can reconnect it, you can get something working without knowing exactly what you did. Or a stick could be holding something in the wrong position, and simply removing the stick could be the fix.
Hope you get that tractor running without too much pain... /forums/images/graemlins/smile.gif
   / B-7500 Won't crank. HELP #24
Thanks, it was very simple. The PTO was in the 540 range. I must have hit the lever when I was getting off the tractor. I now have the job done and the tractor is back home safely.
Thanks again for all your help.
Donny /forums/images/graemlins/smile.gif
   / B-7500 Won't crank. HELP #25
I had a (no start) event today also with my B2710.
/forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif
I followed the advise of Bird & Henro in above posts and crawled under
tractor and observed sluggish movement of the HST linkage and light contact of safety switch. sprayed everything with WD40 and worked the HST pedal vigoriously, now contact with switch has improved and tractor started /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif ....RayBee
2 MONITORS:  HP & SAMSUNG (A53843)
2 MONITORS: HP &...
Unused Delta Crash...
KUBOTA SVL75-2 SKID STEER (A52705)
KUBOTA SVL75-2...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A53473)
NEW 2024 LOAD...
Car Tow Dolly (A52377)
