b/h drive shaft length
   / b/h drive shaft length #1
big bubba
Elite Member
arkansas
M8540
a friend of mine just purchased a Bush Bog 8' twin spindle, nice machine, every bit as heavy duty as my Rhino...the drive shaft is too long, so he's returning it to dealer, although i think he'll have to measure & cut...my question is how much allowance should he figure for the slip joint? around 1/2"? once mounted & in operation, how much does it actually travel? just so it doesn't bottom out, etc. thx!
   / b/h drive shaft length #2
That is an expensive drive shaft. Returning it to the Dealer to have it shortened may not be a bad idea. A lot of variables have to be factored in when cutting or shortening one of the large rotary cutters primary drive shaft.
good point, i'll let him know thx
   / b/h drive shaft length #4
The manual for most implements powered by the 3pt have detailed instructions on how to correctly shorten the shaft.
Here's a video by the awesome folks at Everything Attachments....pretty straight forward really.
https://www.youtube.com/watch?v=0vBFJcvs5SE
most excellent gmanbart this probably will educate the dealer as well
   / b/h drive shaft length #6
Good video, but what is missing (because the video is for a tiller) is that a bushog can raise up MUCH higher than just the 3 point when one backs the bushhog up into a rise! So just measuring with the 3 point lifted all the way will likely NOT be short enough for a bushhog.
- Jay
   / b/h drive shaft length #7
And often one might have it drop down farther than a tiller would (as when I climb up a bank onto the road, which I wouldn't do tilling).
Been there done that.
1989 25'' crosley dove tail trailer (A55787)
1989 25'' crosley...
2014 VOLVO A25G OFF ROAD DUMP TRUCK (A52709)
2014 VOLVO A25G...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2019 CUSHMAN HAULER PRO ELECTRIC GOLF CART (A58375)
2019 CUSHMAN...
16' Heavy Duty Hydraulic offset Towner Pull Disk (A59225)
16' Heavy Duty...
1993 FORD F-350XL SINGLE CAB FLATBED TRUCK (A51406)
1993 FORD F-350XL...
