B1750 HSD 4x4 no go...
   / B1750 HSD 4x4 no go... #11
B2400 said:
My money says the problem lies in the Bi-speed area. .
I was going to suggest that too, except easytractor said the front wheels wouldnt turn even when they were hanging in the air. That must be a very burnt out set of clutches to have no grip at all! But if you've already taken yours apart twice I'd reckon you know what you are talking about.
   / B1750 HSD 4x4 no go... #12
You're right, even toasted they should transmit some power. That leaves a backed off pinion nut or a stripped driveshaft the way I see it. The Bi-Speed unit may be different on the 1750 as compared to my 2400 also. I'm thinking the 1750 uses a normal ring and pinion whereas the 2400 uses a similar but more compact bevel drive. This may make some difference as to how your Bi-Speed transmission works.
2014 Volkswagen Passat (A56859)
2014 Volkswagen...
Unverferth 330 (A53317)
Unverferth 330...
2018 Isuzu FTR 24ft. Box Truck (A55852)
2018 Isuzu FTR...
UNUSED FUTURE MINI EXCAVATOR HYD THUMB CLAMP (A57193)
UNUSED FUTURE MINI...
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
MISC TIRES (A54757)
MISC TIRES (A54757)
