B1750 HSD 4x4 no go...
   / B1750 HSD 4x4 no go... #11
B2400 said:
My money says the problem lies in the Bi-speed area. .
I was going to suggest that too, except easytractor said the front wheels wouldnt turn even when they were hanging in the air. That must be a very burnt out set of clutches to have no grip at all! But if you've already taken yours apart twice I'd reckon you know what you are talking about.
   / B1750 HSD 4x4 no go... #12
You're right, even toasted they should transmit some power. That leaves a backed off pinion nut or a stripped driveshaft the way I see it. The Bi-Speed unit may be different on the 1750 as compared to my 2400 also. I'm thinking the 1750 uses a normal ring and pinion whereas the 2400 uses a similar but more compact bevel drive. This may make some difference as to how your Bi-Speed transmission works.
2013 Ford F-750 Truck, VIN # 3FRXF7FL2DV789551 (A57453)
2013 Ford F-750...
New/Unused Excavator Bush Cutter (A57454)
New/Unused...
2018 Peterbilt 389 Day Cab Truck, VIN # 1XPXD49X6JD476305 (A57453)
2018 Peterbilt 389...
2007 Hummer H3 4X4 SUV (A56859)
2007 Hummer H3 4X4...
New/Unused Quick Attach Bale Spear (A57453)
New/Unused Quick...
Cargo Van (A59230)
Cargo Van (A59230)
