B21 - where is the flasher solenoid located?
   / B21 - where is the flasher solenoid located? #1
nvr-enuf
Hello everyone, i am trying to get my lights behind the seat working and I can not seem to find the flasher solenoid. I found the fuse box but there must be a flasher solenoid between the fuse box and the actual lights. Any help would be appreciated.
thanks
SaS
   / B21 - where is the flasher solenoid located? #2
Hi,
The hazard unit is attached to the wire harness, located behind the instrument panel, near the light switch (left side). It is not mounted on the panel, but just behind it. Looks like you'll need to remove the panel to access it.
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2016 Ford Taurus AWD Sedan (A59231)
2016 Ford Taurus...
2023 CATERPILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A60429)
2023 CATERPILLAR...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
7ft Pull-Behind Rake Tractor Attachment (A59228)
7ft Pull-Behind...
John Deere 5525 (A60462)
John Deere 5525...
