B2320 - how to take off dash plastic cowling
   / B2320 - how to take off dash plastic cowling #1
HCamp
MX5100, B2320
Yesterday I mowed with the B2320 for several hours, turned off the engine for an hour or so, and when I returned to start the tractor up again nothing, no clicks or any other sound or lights on the dash when I turn the key, and no headlights/turn signals when I try the light switch. Battery is fine - I can crank the engine by shorting the starter solenoid terminals, and cranking speed sounds normal, but it won't start, I assume probably because of a stop solenoid on the fuel pump. All the fuses in the fuse box by the starter are good.
Next I was going to check the key switch which is mounted on the big plastic cowling. I have a puller for the steering wheel, but I only see one attaching screw on the center top of the cowling and don't see how it comes off. Would appreciate info from anyone who's done this!
Thanks much,
Howard
   / B2320 - how to take off dash plastic cowling #2
I don't know if ours are set up the same, but my 2650 has 2 bolts down at the bottom of the cowling that need to be taken out.
Joe
I'll check it out. Thanks much!
Howard
2019 Chevrolet Tahoe (A56859)
2019 Chevrolet...
12ft x 8ft Military Flat Bed (A57454)
12ft x 8ft...
Tube Broom 8, 5/8 x 58 Poly 26" (A59076)
Tube Broom 8, 5/8...
(APPROX 23) 2" X 2" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 23) 2" X...
Miller Big 40 Portable DC Arc Welder Generator (A55973)
Miller Big 40...
Dewalt D28755 14" Cut-Off Machine (A59076)
Dewalt D28755 14"...
