Racer11
Anyone use a non ) Kubota air filter,,,I would like something that I could clean and reuse such as a " K&N" filter. The Kubota filter is pricey to be changing all the time.
Ahhh .... why can't you reuse the Kubota filter ?Anyone use a non ) Kubota air filter,,,I would like something that I could clean and reuse such as a " K&N" filter. The Kubota filter is pricey to be changing all the time.
I think the materials used in filters degrade like anything else, becomes brittle, small cracks, who knows. I'm also amazed at how much fine dust comes out of mine when I flush it with air. Over time that has to reduce the airflow because I know I'm not getting it all. Also not sure how many times you can wash something before it wears out. Even underwear can only go through the laundry so many times.Ahhh .... why can't you reuse the Kubota filter ?
They also say you can wash your fuel filter too. Why would anyone risk a $6000 engine for a filter?:confused3:In the newer Kubota owners manuals they do discuss washing and reusing the air filter a couple of times if they are not real bad.
David Kb7uns
Probably true .... at some point ....I think the materials used in filters degrade like anything else, becomes brittle, small cracks, who knows.
Yup - for me it's usually a 20 to 30 minute job, just to blow mine out .... simply because if one is persistent and continues with it, it will continue to produce dust .... patience is the key.I'm also amazed at how much fine dust comes out of mine when I flush it with air.
Likely true .... but then unless you are flow-testing it, it's hard to say whether that reduction is at all significant (and therefore relevant or important)Over time that has to reduce the airflow because I know I'm not getting it all.
Given the manner/procedure that is prescribed for the washing (which is fairly gentle), I'd say quite a few times ....Also not sure how many times you can wash something before it wears out.
Certainly true .... but the common, conventional "wisdom" (or quiet hysteria, if you prefer) regarding vehicle air filter replacement has been affected by the propaganda from OEM's, filter manufacturers, and retailers .... I know - I was one of them onceEven underwear can only go through the laundry so many times.
Yeah .... the low pressure part sticks in my mind as well .... although I swear that when I was looking at the manual the other day it said less than 71 psi .... (not exactly my idea LOW pressure ....The B8200HSTD that I used to have, was an older generation than the B2400. the Owners Manual recomended washing the air filter. They also recomended special Kubota cleaner(added to water). It also indicated to blow the filter from inside out, with LOW pressure air.
I use whatever dishwashing detergent the wife has laying around ....I used to wash mine with solution I got from my local independant shop.
Yeah .... the low pressure part sticks in my mind as well .... although I swear that when I was looking at the manual the other day it said less than 71 psi .... (not exactly my idea LOW pressure ....) .... but it could have been a different piece of equipment ....
Just amazes me that anyone would risk a very expensive engine over the price of a filter. All it takes is a pin hole to dust a diesel.:confused3:
I was thinking Racer11 was saying that uni foam filter would be a pre-filter.I would not replace an OEM type filter with something else, but to each his own.
I used to blow out my filters maybe a dozen times before replacing them, but quit doing that when I noticed that the inner "disaster" filter was contaminated, which I had never seen before.
Now I inspect and just tap the primary filter against the shop floor, and after the 3rd cycle just replace with OEM.
If he was saying to only use it as a filter then no it wouldn’t be a good idea.
