B2410 steering trouble
   / B2410 steering trouble #1
j886
B 2410 HST with front end loader. Just had all filters and fluids changed and now steering is very hard. Only turns a very little unless you are moving foward or backward. I also noticed the power steering and loader take a while to work when you first start up. Read a few post here about possible leak on the non pressure side of hydro system. Just wondering if anyone else has had this problem.
jim
jim460@aol.com
   / B2410 steering trouble #2
Have changed the filters and fluids on mine and not had this issue.
Have you...
1. checked the hydro fluid level?
2. tried lifting the front end with the loader and cycling the steering to bypass on both sides a few times?? Maybe you still have some air to purge.
   / B2410 steering trouble #3
It sounds like you have air in your system. Continue to cycle the loader and power steering...it should work its way out.
Jim from NH
I will try to cycle to bypass a few times. I was also thinking what if mechanic put filters on wronge side, and or did not clean out strainer?
No Kubota oil supplied by me.
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
2017 Ford Transit 350 Passenger Van (A59230)
2017 Ford Transit...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A56438)
2006 Magnolia Dry...
1994 SHOP MADE ENCLOSED TOOL TRAILER (A58216)
1994 SHOP MADE...
KUBOTA M9000 UTILITY SPECIAL TRACTOR (A59823)
KUBOTA M9000...
2017 TERRAMAC RT14 CRAWLER DUMPER (A60429)
2017 TERRAMAC RT14...
