B26 repair of broken u-joint on front drive shaft at HST output
   / B26 repair of broken u-joint on front drive shaft at HST output #51
Kubota makes well engineered machines. Always room for improvement. Hopefully but unlikely they could incorporate a hole and driveline design to better facilitate repairs.
They did improve the hydraulic suction line on the B26 after years of rubber elbow failures.
   / B26 repair of broken u-joint on front drive shaft at HST output #52
Do know what year they did that? I have a 2019 and hope to avoid the issue.
   / B26 repair of broken u-joint on front drive shaft at HST output #53
June of 2020 is when I found out about the upgrade for my 2016 B26.
Should be easy to tell if it has the new designed line as it’s 4pc from the earlier 2pc.
Old design on left, new right.
   / B26 repair of broken u-joint on front drive shaft at HST output #54
Might consider upgrading to replace the worm drive hose clamps - yes, those clamps are cheap, easy to spec, easy to put on, and with a wide range of initial clamping ability - so have become a favorite with some designers. But in long term term they cannot flollow so are not as functional as the constant pressure type on the left hand suction line. Hot hydraulic oil stresses everything and hardens the rubbery parts .
   / B26 repair of broken u-joint on front drive shaft at HST output #55
Good point. Surprised Kubota didn’t source tension clamps from existing stock. All parts came bagged together. Haven’t seen how new B26s are built.
   / B26 repair of broken u-joint on front drive shaft at HST output #56
Finally looked at my B2601 from the bottom. Has NO Ujoint between HST and engine. There's a slip collar connection.
EXCAVATOR GRAPPLE (A53843)
EXCAVATOR GRAPPLE...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2010 INTERNATIONAL DURASTAR 4300 SWEEPER TRUCK (A51406)
2010 INTERNATIONAL...
2021 CHEVROLET SUBURBAN (A53843)
2021 CHEVROLET...
2006 FREIGHTLINER CST120 (INOPERABLE) (A55745)
2006 FREIGHTLINER...
