B2620 fork lift options?
   / B2620 fork lift options? #1
Jbbies
Colorado
Kubota B2620
Anyone have any idea on how or if its possible to use this B2620 to lift a pallet weighing 2000 pounds? I have seen somewhere a 3 point fork lift attachment that has its own base? Any thoughts?
Thanks Brandon
   / B2620 fork lift options? #2
Off the top of my simple head, that doesn't seem possible. ... ....but good luck for somebody that knows how.
   / B2620 fork lift options? #4
I recall seeing a picture several years ago (I think it was here on TBN but maybe not) where someone mounted a forklift mast like that on the 3PH of a Kubota BX, but had small wheels (castered?) at the bottom of the mast to carry the weight. Without those wheels you would need a good size tractor just to carry the mast.
2015 TYTANK PNEUMATIC DRY BULK TANDEM AXLE TRAILER (A43004)
2015 TYTANK...
(4) Foam Filler Tires and Wheels (A44391)
(4) Foam Filler...
(1) HD 12ft 6in Panel (A44391)
(1) HD 12ft 6in...
Ditch Witch DP-190 Packer (A44391)
Ditch Witch DP-190...
2016 Ford F-550 Ext. Cab Knapheide Service Truck (A44571)
2016 Ford F-550...
2015 Ford F-150 Ext. Cab Pickup Truck (A44572)
2015 Ford F-150...
