B2710 Hyd strainer
/ B2710 Hyd strainer #1
MarkLeininger
Platinum Member
Chicago suburban
Kubota 2710
So this moron I know forgot to clean the hydraulic strainer when he changed the hydraulic filter and fluid. Can I pull the strainer without losing much (or hopefully any) fluid?
/ B2710 Hyd strainer #3
It's been discussed a few times. I've never tried it but some say its possible. You'll need something to plug the hole while you are cleaning the screen.
Some have said that a vacuum cleaner held to the top oil filler hole creates a vacuum in the crankcase that minimses or stops the flow through the drain hole. And positioning the tractor (safely) on a slope may help.
Be prepared to catch a lot of oil anyway, or possibly even catch the whole lot. Theres an O Ring that can be fiddly to fit correctly. That could be difficult if you have oil everywhere. By the way, you may have 2 screens. One for the hydraulics and one for the HST (if you have HST)
/ B2710 Hyd strainer #4
Just drain it at the drain plug .
If u can keep the fluid clean strain it and pour it back in.
OK thanks, I think I'll drain it into a clean container and pour it back. Naturally this is the first time in my life I've ever purchased a manufacturer's lubricant, I filled it with SUDT which might be the only thing that won't come down in price even if the world economy does collapse. So I'm not going to lose a drop of this stuff.
/ B2710 Hyd strainer #6
Or, more importantly, if times get really tough you can boil off the lubricant and you will have all of that 24K gold dust left!
/ B2710 Hyd strainer #7
Before you spill oil all over yourself and the floor, let's discuss the purpose of the strainer. It's not like a filter. It's only there to trap debris caused by a mechanical failure in the system, such as a bearing going out, O-ring deteriorating, gear teeth chipping, etc. If you found no evidence of anything like that in your drained oil, I wouldn't worry about the strainer.
I'm betting after you make a mess and look at the strainer you are going to see a perfectly clean strainer that you are only going to risk contaminating. :eek:
/ B2710 Hyd strainer #8
The fine mesh of the strainer slowly clogs up with fine grit and filings that are a natural result of manufacture, running in, and daily usage - not just 'mechanical failure.' A clogged strainer can starve the HST of oil, resulting in major performance problems and ultimately severe and expensive damage.
If you have any doubts - clean the strainer!
This doesn't sound right to me. Engines and hydraulic parts are manufactured to tolerances in the tens of thousandths. If there were grit and filings in the lubricant it would ruin the engine and transmission. I think in the old days (like 50 years ago) this might have been true. I'm inclined to agree with ovrszd that the strainer is to catch catastrophic failures, in which case cleaning the strainer is not my greatest problem. So that means I can sit on the couch this weekend and think great thoughts instead of getting all oily. I'm actually tempted to drive one side of the tractor up on car ramps to see if I can pull the strainer without spilling any oil, just to contribute knowledge to the tractor community. And of course to find out for myself just what's living in my strainer.
/ B2710 Hyd strainer #10
So you really think the strainer is there just to catch the bits when something explodes?
But anyway I didn't say theres grit in the oil. I said it gets trapped in the strainer and ultimately clogs it. Are you aware how fine the mesh of this strainer is? Its almost as fine as cloth. Perhaps you are thinking its coarse like a veggie strainer.
I think the strainer is like the net under a highwire act. Everyone hopes you don't need it, but if you do it's there. How does the grit get into the strainer if it's not carried in the oil? Do you mean grit like from checking the fluid level and wiping the stick with a dirty glove, or are you saying the engine somehow produces grit? We need a card carrying mechanical engineer on this group to answer questions like this. Kubota paid an engineer to design this strainer, we need to track that person down and ask them why they got paid to put a strainer in this tractor.
I talked to one of the mechanical engineers at work. His expertise is cryogenics, but he had some books and papers on hydraulics. Most of it was impenetrable, but there was an interesting section on strainers that I could almost understand. Here's the text:
"However, the majority of components of contaminants in working hydraulic systems are not solid particles like ACFTD but toluene soluble resinous matter, as shown in table 2. Resinous matter has polarity and is adsorbed onto metal surfaces. It is sticky and attracts other solid and fiber contaminents which then stick to them. By this mechanism, suction strainers will be clogged.
A suction strainer is actually a full flow filter. Hydraulic oil passes through a suction strainer at very high velocity. This means that both oil and the strainer will be electrified by friction of oil with the strainer. When oil passes through insulated strainers, static electricity will be accumulated on the strainers and the accumulated electric charge will be discharged by sparks. Spark discharge of static electricity will crack oil molecules and produce free radicals. Free radicals will propogate autoxidation of oil and produce polymerized oil oxidation products (resinous matter). This cycle continues, as long as full-flow filters are used in hydraulic systems."
I found a fair number of anecdotal postings on the internet that strainers are put in by manufacturers to prevent maintenance claims due to poor manufacturing processes that leave nuts, bolts, and tools in the hydraulic system. However they do more harm than good because they get clogged and cause cavitation. The suggestion was to remove the strainers because they aren't necessary and only create a problem.
So, now that I agree my strainer is probably full of grit (sticky resinous material that attracts other crap), I'm headed out to clean it.
/ B2710 Hyd strainer #13
Good idea. Please let us know what you find. (You didnt mentiont if you have a HST by the way). By 'grit' I meant generally anything that shouldnt be there. Even a perfectly built and cleaned engine is going to loose fine metal points off the gear teeth. These tend to sink to the bottom of the tranny case where, in some models, the oil take offs to the HST and other hydraulics tend to be, so they'll go through the HST before they reach the replaceable oil filter. (??) Your comment about the static electricity is very interesting. Some of the later model Kubotas have dropped the strainers, perhaps for that very reason.
Having said all this, I dont actually know if your model even has strainers, but if it does, and you have a HST, you will usually have one strainer each side of the tranny case.
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A65053)
2019 VOLVO A45G...
2017 VERMEER TG7000 TUB GRINDER (A66091)
2017 VERMEER...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
2004 160 LC John Deere Excavator (A62613)
2004 160 LC John...
2017 HAMM H12i PADFOOT ROLLER (A65053)
2017 HAMM H12i...
3098 (A63117)
3098 (A63117)
