B2920 with 2 bottom plow.
   / B2920 with 2 bottom plow. #1
fredhargis
Wapakoneta Ohio
Kubota B2920, Kioto CK3510HB
I'd like a plow to use occasionally for the small garden I have, put in a food plot, and random lawn renovation. My owner's manual suggests a 1 bottom (14") plow, but the only used ones that show up around me are for much smaller tractors, many along the lawn tractor category. I do see quite a few 2 bottom plows (usually 12") show up for good prices. Will this tractor handle that OK?
   / B2920 with 2 bottom plow. #2
Some folks say that 20 HP per bottom is necessary. The other factors are soil type, tire type, 4WD, and so forth so the question about handling a two bottom plow is hard to answer.
You could always convert a two bottom to a one bottom if it doesn't work out.
   / B2920 with 2 bottom plow. #3
I've got a B2630, R-4's (not loaded) and a loader on the front. I've got a Ferguson single bottom plow which has the extra deep 16" bottom. It pulls nicely for me in soil which is on the sandy side. I'm plowing about 8" deep, and I have to use the diff. lock occasionally. I've wondered myself about pulling a 2 bottom 12" plow. I think I'll be happier plowing deeper when I'm turning over my winter rye. These small Kubotas don't lack for power - it's the weight of the tractor that is the biggest issue.
There is a YouTube video of somebody pulling a 2 bottom with a New Holland about your size. He does okay, but it looks like he's working pretty good. A bunch videos of a kid with a larger kubota, but the plow isn't set up very good. He doesn't really have both bottoms in the ground properly - just the front one.
   / B2920 with 2 bottom plow. #4
Exactly.:thumbsup:
Thanks, guys. I had thought about buying a 2-bottom, and converting it. Maybe that's the path I'll take.
   / B2920 with 2 bottom plow. #6
You'll never know till you try. Fill the bucket with rocks.:D
   / B2920 with 2 bottom plow. #7
If it's any help to you, my 2800/3400 manual says I can use either a 2 x 12 or a 1 x 16 plow. Your hp is the same or better than a 2800, so you should be ok. Tough ground may be another story however.
Sean
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
*Selling at Royal Auction Tampa, FL Location* Runs and drives. 52 in deck (A59228)
*Selling at Royal...
Pintle Hitch Triple Axle Trailer - NO TITLE (A59814)
Pintle Hitch...
2015 Nissan Altima Sedan (A59231)
2015 Nissan Altima...
2012 Chevrolet Van (A55973)
2012 Chevrolet Van...
Push Mower (A59231)
Push Mower (A59231)
