B3000/B3030 LED Headlight BUlb ?
   / B3000/B3030 LED Headlight BUlb ? #1
TimP
Platinum Member
Kingsville, MD
B3000HSDCC
Hi All !
Has anyone with a B3000 or B3030 replaced the OEM Headlight bulb with a LED bulb?
I don't know the exact bulb number of the OEM Bulb, but hope someone has replaced theirs already.
THANKS !
   / B3000/B3030 LED Headlight BUlb ? #2
I think the stock bulb is a A-3603.
Hi Moship !
Thank you for the info. I should be able to find a compatible LED bulb armed with that info.
That bulb looks like a dual filament and is supposed to be a 25/25 watt.
So it "should" have a high beam and a low beam setting on the tractor.
But I'll be darned if I know how to switch between low beam and high beam on the B3000.
Regards..... :.)
GRTkub,
Thanks for that link. I did read it, but the link to the 80 wat bulbs he mentioned was no good ay longer.
Those sounded like they would be a good choice.
The other link show a bulb that doesn't look like the same base.
But at least I know there are bulbs out there.
Thanks again.
   / B3000/B3030 LED Headlight BUlb ? #6
I guess I didn't read into it deep enough. I'm interested in upgrading my B2650 bulbs as well so I'll do some looking around too.
   / B3000/B3030 LED Headlight BUlb ? #7
GRTkub,
Thanks a lot for the info.....
Regards.
   / B3000/B3030 LED Headlight BUlb ? #9
I have a pair of LED bulbs in the headlights of our L3830. They throw a lot more light (but not as much as the floodlights that I mounted just in front of the operator station).
On our B7500, it had bulbs sort of like that (I think), but the round fixtures were all sooty and messy, so I replaced the whole fixture with LED floodlights.
Aaron Z
   / B3000/B3030 LED Headlight BUlb ? #10
The finished B7500 headlight replacement:
The bracket:
The hood upside down before the cowl went back on:
Aaron Z
2020 International MV607 Truck, VIN # 1HTEUMML3LH587955 (A44391)
2020 International...
1671 (A44572)
1671 (A44572)
CIC Contractor's Crossover Toolbox w/ 3000W/6000W Inverter, Air Compressor, Jump-Start Capability (A46877)
CIC Contractor's...
More info coming soon! (A44572)
More info coming...
2001 Ford F-650 Altec TA40 Bucket Truck (A44571)
2001 Ford F-650...
Kivel 48in Forks and Frame Skid Steer Attachment (A44571)
Kivel 48in Forks...
