Oil & Fuel B3030 fuel consumption
   / B3030 fuel consumption #11
the rule with a diesel is more load = more fuel, once you get above about 3/4 rpm you fuel usage will also increase dramatically, bit hard to keep rpm down when driving a pto implement, because all of them usually should be run at 40rpm, which on most smaller tractors is near enough to WOT. 1 gal an hour is up there, but not what i would call extreme, just gettin towards that end of the scale.
   / B3030 fuel consumption #13
On my B-7800, I use just about a tankful (I think it is 7 gallons or so) in 8 hours of mowing with a 60" MMM running at 2200 to 2300 rpms. Also I did notice when I was using the rotary cutter, it seemed to use more fuel than mowing with MMM. With my old B-7200 which was a gear tractor and around 17 engine HP I would mow for about 8 hours on 4.5 gallons of fuel with 60" MMM as a comparison.
1997 Generac T/A Towable 175kW Diesel Generator (A56857)
1997 Generac T/A...
2006 PETERBILT 379 (A58214)
2006 PETERBILT 379...
GEARMATIC WINCH (A58214)
GEARMATIC WINCH...
Lee Boy 250 Gal Tack Distributor (A53317)
Lee Boy 250 Gal...
2015 12ft Towable Hot Pressure Washer Trailer (A56857)
2015 12ft Towable...
2013 Ford Edge (A54815)
2013 Ford Edge...
