Buying Advice B3200/b3030 or L3800?
   / B3200/b3030 or L3800? #1
Rhino421
Milwaukee, WI
B26 TLB
Hello to all,
Hit the wrong button didn't get a chance to write anything:ashamed:...
Here is what I meant to write... I have 2 acres of wooded property which I have alot of landscaping to do and lots of time to do it. I will be adding 200 plus yards of fill, topsoil, seed, etc. I want to push my woodline back which means clearing aprox 1/2 acre of trees mainly 2-6" diameter, clearing site for 24x30 slab, maintaining 200' gravel drive, grading, snow removal (blade). and firewood hauling. I also maintain 60 acres of hunting land with friends in which we brushhog trails and hopefully create a few deer plots next year. We have been borrowing a friend's tractor 6000lbs but it is a chore to arrange this and the vehicle/ trailor to transport this much weight 200 miles one way. He does have every 3 pt implement I could ever need just laying around and even a backhoe for the really big jobs at my property:D. I was looking at the B series for the size around my house but feel they may be too small for the hunting property. I saw the L3800 and it is just a little bigger footprint but 800lbs heavier and may work better for land maintainace and still light enough to tow. Brush hog is 5 ft HD and currently on hunting property. I was wondering if any b3200/ b3030 owners have used them for deer plots, etc and found them too light or underpowered( pto wise):). I believe the L3800 wound do the job but unsure if it would be a hair too big to be productive on my 2 acres. I don't plan to mow with them. The price of the B3030 and L3800 are fairly close to each other. Thanks for reading and any advise on these units. Pictures of my home lot are below
   / B3200/b3030 or L3800? #2
If the title to your thread here "b3200/b330 or l3800" is a serious question, then you need to give a LOT more info than just a "hello to all".
So until you give us some more info as to what you are wanting to do with a tractor, I will have to advise that you should just buy them both and be done:thumbsup:
   / B3200/b3030 or L3800? #3
Welcome to TBN Rhino, we should be able to help you spend your money here. I say go for the L3800 for now, and after you got all the heavy work done, you can trade down, of course spending someone else money is easy. I think, a new L3800 is not over kill even for the lesser chores of maintaining the property, after all the heavy stuff is done.
   / B3200/b3030 or L3800? #4
with what your saying you want todo an maintain id go with the kubota 3800.its the right size for the jobs you want todo.
   / B3200/b3030 or L3800? #5
That paints us a better picture:thumbsup:
Id go with the 3800 if you have no intentions of mowing with it. It is built a good bit beefier and has stronger lift capacities but isnt too much bigger than the B.
I would also advise to NOT use your friends 3PH BH on the L3800. Unless it is a VERY small one.
3PH Backhoes but ALOT of stress on the toplink. There have been people break the whole top of the rear end casting off using 3PH Backhoes on these smaller tractors.:confused2:
   / B3200/b3030 or L3800? #6
I was facing a similar choice recently, and I opted for the L3800HST. It looked massive in the showroom next to the B models, but in the field it isn't. It's just right for me. And once you start moving dirt with the FEL, it seems pitifully small :laughing:
Go for the bigger model, you won't regret it.
   / B3200/b3030 or L3800? #7
The B3200/3030/3000 are really nice little tractors indeed, but of those listed my choice would be the L3800 without a doubt. If you were just working on your two acres, my recommendation might be different, but you often times must buy for the tasks and not the acreage, so even on a small plot a bigger tractor might be indicated.
Thanks for the input thus far:D... Troy I am taking this slow so I hopefully get the right size so I don't have to downsize in the future or upsize later:thumbsup:.. I started looking last year and was about to pull the trigger on a BX25 and glad I didn't for I know that was too small. I have since gone through a list of tasks for now and later and thus looking larger. I also need to transport this tractor several times a year and too big could be a problem. This is why the b3200/3030 came into play. I just wasn't sure if these tractors would be too light for brushhogging and deer plots grant it this is only a few times a year. The l3800 seems to be a good compromise and I can get it cheaper than the b3030 with the current loader rebates:D. I just haven't been able to test one with the loader or implement on the back yet due to dealer still getting his inventory setup and all the cold and rain lately:(. ZMJC have you noticed any jerkyness of the 3pt that I heard was a problem with the L3400? I am heading to the hunting land this weekend so I won't be able to test drive these units til next week (took off to do some serious looking:cool:). LD1 my friend's hoe isn't a 3pt i would have to borrow the entire tractor which is always a production by itself. Thus the idea of a hoe of my own someday:laughing:...
   / B3200/b3030 or L3800? #9
No, I haven't taken the backhoe off yet to test the oft-discussed "jerkiness" of the 3PH. Being a tractor newbie, I don't have much to compare it to anyway.
- Mike
   / B3200/b3030 or L3800? #10
I have a 2008 L3400 and the 3pt is good I see what they mean about being jerky but it is nothing that afects the operation of the tractor it does not bother me and I would buy the tractor again and feel good about recomending it to you. Not sure if the L3400 is still in production but it sounds like it would be a good match for the work you have lined up. I went with the gear drive and ag tires and think they would work well for you to.
TPM 18K Mini Excavator (A47809)
TPM 18K Mini...
Boat Trailer (NO Title) (A47809)
Boat Trailer (NO...
Fertilizer Spreader (A47809)
Fertilizer...
2019 Genie GTH-844 (A46443)
2019 Genie GTH-844...
1992 Jeep (A46443)
1992 Jeep (A46443)
Trash Combo Trailer (A45336)
Trash Combo...
