b3200 how to bypass all the safety switches to get started when in woods
   / b3200 how to bypass all the safety switches to get started when in woods #11
Don't know how it works on a Kubota but on our NH the fuel solenoid is located where I can pull the wires and unscrew it from the injector unit. With the solenoid removed the fuel is ON and it will start (I found this out when we were having start problems that turned out to be a bad fuel solenoid). While running with the solenoid removed it could be possible for oil or fuel to de discharged so I would only do his in an emergency.
   / b3200 how to bypass all the safety switches to get started when in woods #12
Kubota has used Both a fuel "shut Off" And a Fuel "Hold On"...
It's easy to tell the difference if you watch how they work.
Next time you have it running take a picture of the injector pump & solenoid.
Then take the Same picture with it Off,
Compare the pictures and you 'May' see the levers you need to move that 'May' be external to the injector pump. KennyV
2014 Freightliner M2 106 Palfinger PK22002EH 6 Ton Knuckleboom Flatbed Truck (A55973)
2014 Freightliner...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
2020 John Deere 1025R MFWD Compact Tractor (A56438)
2020 John Deere...
