I'm having a hard time deciding on a new tractor. (size and brand) What I would like is a tractor that compares to my current Mitsubishi MT250D. It weighs around 2000# and has a 5' FEL. I have 20 acres where I live which I'm always moving dirt, getting firewood, and mowing 3 acres of grass. I also have 100 acres 10 miles away that I am improving for hunting and outdoor recreation. This includes pushing brush, creating foodplots, planting trees, ect... The land has some flat and some fairly steep slopes (250D makes me nervous). I would like to get FEL, BH, Bhog, and either MMM or 3pt FM. After I decide on size, then I think it's either Kubota or Mahindra. Also, my trailer is licenced for 5000#, so would it haul the "L" with implements or do I have to replace it too? Thanks in advance.
i was faced with a simular decision you have now. looked at both models. i do everything you mentioned you want to do with my
b7800 (very simular to
b3200, i am looking at getting a
b3300). for your decision making purposes, i also live in pa and operate mine on very steep slopes (you have to be careful) and i do tons of firewood winching/skidding, bush hog many acres, move tons of dirt/stone, and plow many dirveways each winter (small side business). i trailer mine to different firewood/mowing sites with my 7000lb rated tandem axel trailer. with implements on too. tows pretty good. the L would be pushing it, and defintly pushing it on your 5000lb rated trailer. the weight between the two=
b3200=2600lb with fel and loaded tires.
L3200 around 3200lbs-3700lbs with fel and loaded tires. the b has a 1/4" 3ph valve=silky smooth, but will
very slowly leak down over 20 minutes or so (not bad, but for some can get annoying), the L has poistion control 3ph which maintains height while operating, but i have heard the XX00 series can be jerky at times. the b has a mid pto, the L will not. the b has a 4 cylinder engine, the L has a 3 cylinder engine. these are the major differences that come to my mind at this time.
mahindra makes good tractors, but are heavier in weight. i get along fine with my
b7800 (2600lbs with fel/loaded tires) with what i do. i have also pushed brush/piled and poped out small shrubs/thorn trees (up to around 4"diameter trunk) the L would push/pull more just because of its extra weight. but might not work as well lawn mowing and such. like i say i do get along with my b , and yes there is times i could have used a heavier tractor to pull more, but that is not too often compared to the times i like the lighter weight with what i do. lots of times it is more technique then brute force.
i have not run a back hoe on mine, but from my experience with kubota small mini exevators, and watching my friend on his bx series back hoe, i do not think you will have any problems digging with either the b series back hoe or the L series.
LD1 is right. both will work for you, but you should test them all out and see what one you like best with what you have to work with.
as for the mmm or rear finish mower, in your case, i would go with the rear finish mower. easier maintenance (can lift up on 3ph to get to work on, be sure to safty prop it up) and it is easier to take on/off. and if you don't see a need for the mid pto (mmm or front snow blower) then i would look at a b3300su. same tractor as
b3200 but no mid pto (saves you around $1,000) and can be fitted with the larger r-4 industrial tires that will gain you about 200 lbs over the
b3200 if you fluid fill them. and which ever tractor you do get, i suggest you get the tires loaded.
as for the remotes, i believe they do not come standard on either tractor, but can be added for between $600-$1000. they are for running implements that require hydraulic fluid to run (ex: wood splitter, tilt blades on 3ph back blades, and such). could potentially do the same things off your loader valve, but would have to disconnect the hoses off loader or take loader off. depending on how much you see a need for this, they can be a good idea. also they can be added at any time later on if you feel the need for them. good luck and enjoy shopping around.
