B7100 fan quit spinning
   / B7100 fan quit spinning #1
grossgary
midatlantic
1994 Kubota B7100 HST 4WD
the belt was riding around the fun pulley but the pulley/fan wasn't spinning. I assume the fan clutch or bearing is seized.
is it a bearing or a clutch?
and is that just a order it from Kubota deal or am is there a simpler method?
   / B7100 fan quit spinning #2
Chances are it is the dynamo that is seized. :(There is no clutch
Will you be doing the repairs yourself?:D
yes. what does the dynamo do? i guess the smiley indicates this isn't an easy job?
   / B7100 fan quit spinning #4
The dynamo is Kubotas terminology for alternator. :D
I have changed mine out for the same reason you probably have to change yours out. That means it's not very complicated.
If you do it yourself take the hood off, remove the rads and its real easy. There will be one bolt that is hard to access. My toolbox contains a bent combination wrench that will fit. Others have used one of the ratcheting box end wrenches with success. :D
The replacement dynamo will not be cheap. :(
You may be able to take the dynamo to a shop and have it rebuilt at a lower cost??:confused::confused:
Now I am assuming it will be a seized dynamo. My trouble shooting skills are limited.:eek:
doing a search i see guys mentioning that you can run the tractor on just the battery for quite some time.
since the B7100 doesn't have a water pump i don't have to worry about that - so does this mean i could finish my plowing/planting i was doing when the belt broke?
what all requires battery to operate once the tractor is started? is the fuel pump electrical in nature?
   / B7100 fan quit spinning #6
The fan has to be turning to keep the engine coolant cool and the hydro coolant cool.:D
You could run for quite a while on the battery or just boost as required.
I should have mentioned that the little bronze, on mine, round thing is the dynamo.
crap, i forgot about that. looks like they're only $150, so no big deal, except time.
   / B7100 fan quit spinning #8
A couple or three hours it took me. I'm slower than normal.:D
great thanks for the info, it should take me about the same!
out of curiosity - does the fuel pump or anything use electricity once it's started?
wondering how long it'd run if i could free the fan up and the battery was fully charged? a few hours?
   / B7100 fan quit spinning #10
Chances are it is the bearing in the dynamo that has seized up. It may be possible to get it loosened up.:D
As for the rest the only thing 12 volts is required for is starting. Everything else is mechanical. Once running it should go till it runs out of fuel.:D
That is a good time to check the bottom of the tank for debris!:D
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
UNUSED FUTURE FT20 EXCAVATOR (A52706)
UNUSED FUTURE FT20...
Portable Restroom (A54865)
Portable Restroom...
2011 Kia Forte Sedan (A55853)
2011 Kia Forte...
