B7100 Rear Differential Oil Change
   / B7100 Rear Differential Oil Change #1
Shootingstar
San Jose, California, USA
Kubota B7100
I am changing all the fluids in the old B7100 I bought. I can see how to drain the rear differential, both sides, but can't see how to refill.
I did notice that when I drained the transmission and cleaned the filter I could not get the prescribed 12.2 qts of Kubota UCD into it. Makes me wonder if it also fills the rear differential.
Anyone give me advice?
   / B7100 Rear Differential Oil Change #2
Is this a gear model or HST?
Egon. /forums/images/graemlins/grin.gif
   / B7100 Rear Differential Oil Change #3
<font color="blue"> Makes me wonder if it also fills the rear differential. </font>
Transmission and hydraulic system use same oil and filler. Not sure how much oil is needed.
Yes, it is a gear model. I see two drain plugs at the rear differential (both sides) but I can's see how to refill....thus I suspect it is filled via the transmission. My manuals don't discuss this and barely acknowledged the drain plugs.
Thanks for the help so far.
   / B7100 Rear Differential Oil Change #5
Mine Has HST so fraid I will not be of help.
Egon
   / B7100 Rear Differential Oil Change #6
HI, On my 7100, you refill the rear differential by way of the transmission filler on the top of the gearbox. the oil fills both transmission and axle case...... I hope this helps
Thanks, that's what I suspected after not finding the manual's 12.2 qts after draining the transmission. After refilling it, I then discovered the two drains on both sides of the differential. I hadn't drained those. Having had already refilled with the Kubota UDT (expensive) I didn't want to drain again so I let a little out of both and capped them. Fortunately the oil looked clean when draining original oil, and the differential looked clean too.
At least I got about 8 or 9 new quarts in /forums/images/graemlins/blush.gif
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
2005 GMC Canyon (A57148)
2005 GMC Canyon...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A61307)
2019 Krause...
WHITE PINE TONGUE & GROOVE (A60432)
WHITE PINE TONGUE...
2015 CASE SV280 SKID STEER (A60429)
2015 CASE SV280...
UNUSED SDLANCH SDLL60 STAND ON SKID STEER (A60430)
UNUSED SDLANCH...
